Have to replace msi ms-7184 motherboard. What is sutable or correct.
    Master:
  • 788 Answers
You need a Micro-ATX Socket 939 mainboard with the ATI RS482 chipset and SB400 south bridge to be safest, you may even get away with not reinstalling Windows. If you're willing to reinstall Windows then any Micro-ATX socket 939 motherboard that is compatible with your CPU (should be 99% of motherboards) should do the trick. Here is a link to the manual for your ms-7184 mainboard: http://217.110.237.67/Manuals/7184-engl%20v1.x.pdf
Posted on Apr 22, 2008
    Sergeant:
  • 264 Answers
I do not know why u wanna replace it as it is a good one.
If you wanna replace it as its not working that you may go for the same one
    Sergeant:
    Champion:
  • 304 Answers
You want to upgrade your mobo..?
  • Elizabeth Krijt
    Elizabeth Krijt Apr 22, 2008
    ASUS A8V Deluxe - motherboard - ATX - K8T800 Pro
    General
    MPN: A8V Deluxe, 90-M9L0A0-G0EAY
    Product Type: Motherboard
    Form Factor: ATX
    Width: 30.5 cm
    Depth: 24.5 cm
    Compatible Processors: Athlon 64
    64-bit Processors Compatibility: Built-in
    Processor Socket: Socket 939
    Chipset Type: VIA K8T800 Pro / VIA VT8237
    Max Bus Speed: 2000 MHz, 1000 MHz
    BIOS Type: AMI
    Storage Controller: Serial ATA-150 (RAID), ATA-133 (RAID)
    Processor
    Installed Qty (Max Supported): 0 ( 1 )
    Memory
    Supported RAM Technology: DDR SDRAM
    RAM Installed ( Max ): 0 MB / 4 GB (max)
    Supported RAM Speed: PC2100, PC2700, PC3200
    RAM Features: Unbuffered, two DDR channels
    Audio
    Audio Output: Sound card
    Signal Processor: VIA VT8237
    Audio Codec: Realtek ALC850
    Sound Output Mode: 7.1 channel surround
    Telecom / networking
    Networking: Network adapter - Marvell Yukon 88E8001 - Ethernet, Fast Ethernet, Gigabit Ethernet
    Features
    -BIOS Features: DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, JumperFree, ASUS MyLogo2, SMBIOS 2.3 support, ASUS EZ Flash
    -Manual Settings: CPU frequency, processor core voltage, memory voltage, AGP slot voltage
    -Hardware Monitoring: CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
    -Sleep / Wake Up: Wake on LAN (WOL), wake on ring (WOR)
    -Hardware Features: Chassis intrusion detection, ASUS POST Reporter, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, ASUS Instant Music, AMD Cool 'n' Quiet Technology, ASUS Q-Fan 2
    Enjoy
  • 19,396 Answers
Depends, what cpu do you have or you want to use?
  • Ginko
    Ginko Apr 22, 2008
    You need to buy a micro atx socket 939 motherboard. Further details depend on what cpu you have, check that the cpu is supprted by the motherboard.
  • Ginko
    Ginko Apr 22, 2008
Msi ms-7184 ati rs482 socket 939 motherboard stuck on hp invent
Hello Sammy, try pressing and holding the power button to turn off the computer. Unplug the computer from the wall and wait 10-15 sec. Plug it back in and power it on. See if that works.
Dec 30, 2013 | Computers & Internet
MSI MS-7184 keyboard usb and ps 2
Sounds like your processor might be heating up too fast. I would take the computer apart, clean it removing all dust from the fans, check to see if the fan is actually spinning and check to make there the silicon glue has not dried up. It could also be that your power supply isnt supplying enough power but if you haven't added any devices that wouldn't be the issue.
Nov 21, 2013 | HP Amethyst motherboard MSI MS-7184 Socket...
Windows Xp Pro installation cannot find the sata hard drive. It's also not recognized in the bios. I need the drivers contained on a floppy Where can I get said drivers. A search on the internet p
Hi, forget the driver, try replacing the sata cable, reseat or clean the sata port. do isolation by trying the drive o another PC.You may have hard drive issues.
Jun 20, 2013 | Tyan Tomcat K8E Motherboard
Here's my system: MSI MS-7184 Motherboard AMD Sempron 3200+ 1.8GHz 2GB RAM Windows 7 Home Premium 32-bit Problem: I bought a Powecolor HD 4650 1GB DDR3 and when I inserted it in my computer. It...
Judging from the symptoms you describe I suspect that your graphics card is faulty. Did you buy the card new? If so, I would suggest returning it & asking the store to test it for you.
If it is determined that the card is not faulty, reply to this post & I will try to help you further.
Best wishes,
Graemevm
May 03, 2011 | ATI RADEON HD 4650, PCI Express Video...
HP Media Center m7248n Desktop PC will show blue set up screen but when you hit F1 for set up it SAYS it is entering set up but locks up. Motherboard is an MSI MS-7184
Disable few Hardwares in the CMOS setup. and then try again. This usually happens where there is an additional hardware in which the windows while loading is unable find the IRQ
Sep 22, 2009 | HP Media Center m7248n (EK408AA) PC...
Hp ms-7184 AMD base when windows is about to
ok this can be caused by a LOT of things but easier first check your cdrom/dvddrive. make sure clean and pretty.
did you reformat the drive?
what operating system?
Sep 12, 2009 | HP Computers & Internet
I need ms-7267 ver 4.2 drivers
I want to download driver mother board ms-7267 ver:4.2
Jun 07, 2009 | Intel Motherboard
REPLACING MSI MS-7184 MOTHERBOARD - WHAT IS CORRECT REPLACEMENT
Any other brand will do the job as long as its a socket 939 but i strong recommend AMD Athlon 64 socket 939.
U can search for any socket 939 they will work.
Get bac @ me!
KJ
Apr 22, 2008 | ASUS A8N-E Motherboard
What the pins for the power switch, HHD indicator light, power light, and reset on an MS-7184 Motherboard.
Apr 22, 2008 | Computers & Internet
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
