My brake light does not come on with the foot pedal or the hand control. foot stopped working months ago. the hand control just went out. I tried to cross jump the back switch and the light did not light up. I also turned on the key switch several times and still nothing but 1 time it worked till I turned the key switch off again. any ideas
Hi, Anonymous before diagnosing any brake light issue always check the bulb and fuse first for integrity a brake light staying on is usually caused by the front brake light switch, which is mechanical, not disengaging. On early models moving the throttle control housing closer to the front brake master cylinder is the main fix. On late models, the switch gets tweaked and needs to be realigned. A brake light that does not come on when the brake lever is applied can be caused by a faulty switch or no continuity in the wiring at the switch. The rear brake light switch is hydraulic and it is extremely rare to malfunction in a closed circuit condition causing the brake light to stay on. Usually, rear brake light switch issues are caused by no brake pedal free play or a sticky rear master cylinder piston. A brake light that does not come on when the rear brake pedal is depressed can be caused by a faulty switch, air contamination in the brake line, or no continuity in the wiring at the switch. Finally, most tail light wiring harnesses run under the rear fender held in place by spot-welded clips. Worn out rear shocks or lowered suspension can bottom out causing the rear tire to come in contact with the wiring harness, rubbing the insulation off, exposing the bare metal inner core, allowing it to break or short out.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day.
https://www.hdforums.com/forum/dyna-glide-models/106572-rear-brake-light-not-working.html
http://www.mediafire.com/file/g3h2vn0nvw3b5wb/2001_Harley_Dyna_Service_Manual.pdf/file
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/service/document/6300
https://www.6ya.com/how-6ya-works to speak to me personally.
SOURCE: steering wobble at 65km decelerating
No this is not normal. I had to go through 2 different times having a tire balanced once to get a wobble out.
SOURCE: My rear tail light does not work when the front
You should have two filaments in the reat taillight lamp, one for tail light and one for brake light. You are not confusing these filaments/functions are you?
What you seem to be saying to me is that you have a lamp that had no tail light filament (burned out) but does have a brake light filament still intact.
Remove the light and check it visually and/or with a contunity tester.
I hope this helps you ...
If I misunderstood your question, please ask me again
a
SOURCE: have tail light working but brake light does not
Starting at the rear brake master cylinder, follow the metal line back towards the rear caliper. you will find a brake pressure switch in the line somewhere. Make sure all connections to this switch are secure.
If so, check the rear bulb for a blown filament. It has two filaments, one for the tail light and one for the brake light.
SOURCE: harley 1998 ultra wiring schematic
Sorry but I don't have a wiring diagram that I can send you but I may can offer a bit of help.
Your passing lamps are simply wired into a hot circuit somewhere. A lot of schematics don't show them because they are considered "add ons". They also may have a fuse inline with the "hot" wire. They have only one wire that connects them to the bike with the rest being inside the "light bar" itself. Find the wire coming out of the center of the "light bar" and trace it back to where it hooks up. Sorry but that's the best I can do on this one.
On your front brake light, there is a switch located inside your right hand switch housing where your throttle is located. It is a plunger type switch that is activated when you pull the front brake lever. A simple test of the switch is to loosen the bolts of the master cylinder and slide it towards the center of the handlebars. If the switch is good, the brake light will come on. If the switch is bad, it will not.
To get to the switch, you'll have to take the right hand switch housing apart. First, loosen the throttle cables at the adjusters and then remove the two bolts that hold the switch housing halves together. Carefully open up the switch housing. You will see the small switch in the front of the housing. You'll have to desolder the wires, replace the switch with a new one, and resolder the wires to the new switch.
Reassembly is the reverse of the disassembly. Make sure you slide the master cylinder all the way back against the switch housing or the brake light will stay on constantly. Readjust the throttle cables and check for proper operation. You don't want your throttle sticking.
Good Luck
Steve
SOURCE: brake light not working on 2007 ultra classic foot
Sounds like you've got a bad front brake light switch. This little switch is inside the right handlebar switch housing. You can replace the switch by removing the throttle cables and taking the housing apart. Unless Harley has changed something, the switch is not difficult to change but the old wires have to be resoldered onto the new switch.
Good luck
Steve
