Question about Frigidaire FRT15G4B Top Freezer Refrigerator
I have a frigidaire 20 cubit foot freezer that is two years old. The motor is very hot and so is right side of freezer. I'm wondering if a part has been recalled on this freezer or what the problem might be
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
BNewberry
  • 93 Answers
SOURCE: freezer control is set at
if its less than one year old you should be able to call for warranty service and have your machine fixed for free.
go to www.frigidaire.com and search for servicers in your zip code. If you have no luck with that let me know, i can further assist you.
Posted on May 15, 2008
SOURCE: freezer won't freeze
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Posted on May 19, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
  • 103 Answers
SOURCE: Frigidaire #FRS24XHA is hot to touch and freezes food on the left
Hi: Those areas are designed to be warm to keep moisture from forming there(Moulion coil). When they get hot it means the fridge is over working. The condenser coils remove the heat from the fridge. When clogged the heat will leave anywhere it can. The moulion coil is the strip you described,and will overheat when the condenser coils wont disperse the heat. Most likely the coils need a good cleaning, on the bottom of the ref. Use a coil brush and a vacuum. Or even an air compressor to blow the dust and hair out; plan on dusting the house too. Pull the grill off the front and clean them. If real bad pull the panel of the lower back and clean it out too. Since you work in detroit the dust and hair on the coils would be like putting a blanket over your radiator. Parts would heat up. I hope it's just the coils. If a compressor is failing you can get the same symptoms. I hope it is the latter for you, as I'm in your boat also. I hope this helps, Jeff
Posted on Jun 09, 2009
I have 20 cubic foot frigidaire freezer 2 years old. both of the sides are warm to the touch.(approx 70-75 degrees) the door is cold. inside no problem. very cold question: is this beginning to fail and...
YOU HAVE TO REPLACE THE CAPACITOR ON THE COMPRESSOR.. THAT WILL TAKE CARE OF YOUR PROBLEM,, YOU CAN ORDER AT TVPARTSANDMANUALS. COM THEY HAVE PARTS FOR APPLIANCES.. THEY ALSO HAVE A UNIVERSAL ONE THAT IS EASY TO INSTALL COMES WITH INSTRUCTIONS.
Dec 14, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
FRIGIDAIRE UPRIGHT FREEZER COMPRESSOR VERY HOT
Well I finally found the screws for the front grill. The compressor started cooling off once the seal was put back in place. So I'm going to give that a day or so. Still did not find the coils I'm assuming that they are in the sides. One thing I do know for sure, is that I'm putting you guys in my favorites. I educated myself so much from your website. I'm not sure I ever had a problem except the seal. I don't have the original motor to check but I'm working on getting it back. If I would have found this website before the tech I would have saved $150.00. Thank you so much.
Jul 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a 20 ft. Frigidaire upright freezer ab out 10 years old. Model #FFU2QF9FW1 and it will not stay cool enough so that items are about half thawed out. It takes it 3 days to freeze l/2 pint of water. I...
Sounds like it is not working properly to me. If not done already, clean out the radiator and air vents around the compressor to aid cooling.
All freezers and fridges are designed to work in a hot climate so ask if it needs the gas pressure increasing.
If it is gong to cost a lot, now may be the time to get a new more efficient one, it will save you money in the end.
Aug 09, 2017 | Frigidaire 20 cu. ft. / 566 liter Upright...
Compressor clicking on/off - freezer and refrigerator losing cold
I have a side by side frigidaire refrig about 4yrs old, but lately the freezer is not getting near as cold. My built in gage says it is a t 17-20 deg F even after I try to program it to 1 deg.
Apr 15, 2009 | Frigidaire FRS26R4A Side by Side...
Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Jan 11, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer side warm had repairman lookat problem said it had small
if you went to the back of your refer,to the compressor and held the high side line[smallest tubing leaving the compressor]it should be very hot almust uncomfortable to hold if you have the proper freon charge.this is while its running off course.God bless,tom
Jan 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
My light works but the motor won't kick on, Frigidair top freezer
THE CURCUIT BOARD IS NOT SENDING A SIGNAL TO YOUR MOTOR WHICH ENABLES YOUR MOTOR TO KEEP THE VALUBLE CONTENTS IN YOUR FRIDGE COLD...(BEER) EVERY MANS FAVOURITE HOBBY...CHECK YOUR CIRCUIT BOARD FOR CORROSION OR DAMAGE...HOPE THIS HELPS...IF SO SEND ME A COLD ONE
Dec 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire humming freezer not cold enough
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
