Question about Car Audio & Video
Toyota hi ace 1996 2 litre 1rze problem Hi idle speed no fault codes coming up on scanning
  • 1,906 Answers
Using a vacuum gauge attached to the intake vacuum port engine running,
look for a air vacuum leak.
too much air coming into the engine= high idle speed it usually doesn't set a code
unless it gets bad.
Posted on Jul 23, 2010
Hi I have 2003 Toyota voxy it have a 1az fse engine problem is loss of power ,low idle ,sometimes misfiring and when turn on a/c its keeps idling up and down,already scan engine nothing have shown up.
there will be faults so have the faults read by a professional with experience on your engine
all of what you describe will leave fault codes
Nov 27, 2016 | Toyota Cars & Trucks
Engine Code P0171 Logged
If Short term # is high while underway, but normal while idling, you could have a scewed maf signal. Sometimes cleaning maf with carb cleaner helps. If no intake leaks are found, and fuel pressure and volume are ok, it could be maf sensor.
Jan 18, 2016 | 2007 Toyota Hi-Ace 220
Toyota engine 1rz
rough idle can be caused by vacuum leak, test the lines into the intake, if the dont hold vacuum, follow the line to detect the cause. Also the PCV could be broken and lead to a wrong air mixture. If check engine light is on I would expect lean bank codes...
Apr 19, 2014 | 1995 Toyota Hi-Ace
Hi idle speed for 2001 silverado
The first thing you need to do is to scan your onboard computer network for fault codes. The idle speed is controlled by the computer via the Idle Air Control (IAC) valve. Which is a pulse-width modulated electric motor. If the Powertrain Control Module (PCM) cannot control the idle speed correctly, your check engine light should be coming on (this should be your first clue to get it scanned) and there will be fault codes stored that will be helpful in identifying the cause of the problem. It could be several different causes including a failed IAC, damaged or corroded wire connectors, damaged wiring (rodent damage is pretty common), or even a failed PCM.
On the other hand, there is always the possibility that you simply have a really bad vacuum leak and the high idle speed has absolutely nothing to do with any of the previously mentioned possibilities.
Proper diagnosis and system testing would be required before I could advise you with any accuracy about any definite "fix" for your problem.
Apr 03, 2012 | 2001 Chevrolet Silverado 1500
I have a toyota premio year 1996, the ABS light on the dash board is lighting. How can i solve this problem?
Hi Rveerai, Your best course of action is to have a scan carried out o the vehicle and you'll then be able pin point the problem. It could be a fault with any one of the wheel sensors or the unit and pump. The most likely place is a wheel sensor. Regards Johngee10
Jun 03, 2011 | Toyota Corolla Cars & Trucks
Engine fluctuating and cutting out all the time when slowing down to stop cos the revs drop too low
Hi.
If engine revolutions are going up and down even when you are driving, then you have a problem with the EGR valve.
If problem is only when engine is idle, most common fault is the IAC (idle air control) valve, which regulates air when engine is idle. If IAC is OK, check air intake and the sensors installed in the air intake (MAF and IAT). The sensors detect the amount and temperature of air coming into the intake and determine the right amount of air to be mixed with fuel and injected.
There are more problems that even if less frequently can cause rough idle. A good thing to do would DBII DTC scan can be done for free at the nearest Autozone.
Regards.
Ginko
May 31, 2011 | 1996 Audi A4
Check engine light comes on when idling. goes out when driving
Hi and welcome to FixYa!
If the check engine light is on then it can be a faulty sensor somewhere. We won't know until you take it in for an engine scan. On the engine scanner it will list fault codes and by then you'll know what sensor needs replacement.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 22, 2011 | 1996 GMC Sonoma
1996 ford bronco 5.8 litre, auto, engine idle has
Do you have a check engine light on? First thing I would do is unplug the IAC motor when the engine is warm. If the idle speed doesn't change you have a vacuum leak or a bad IAC motor. If the idle speed goes down you might have a bad TPS or IAC
May 31, 2010 | 1996 Ford Bronco
1996 monte carlo fault codes po300, 441, 705,
THESE ARE FROM THE GM CODE DIFINITION MANUAL, U NEED TO TAKE THIS TO THE DELAER, U HAVE SOME SERIOUS PROBLEMS TO GIVE THIS MANY CODES.
P0300 - Engine Random Misfire Detected
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0705 - Trans Range Switch Circuit
P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
P1662 - Cruise Lamp Control Circuit
P1672 - Low Engine Oil Level Lamp Control Circuit
P1870 - Transmission Component Slipping
Mar 24, 2009 | 1996 Chevrolet Monte Carlo
Base idle speed adjustment....1KZ-TE 3.0 litre turbo.
Hi djay,
the idle speed control can be adjusted on the pump by turning the adjusting screw that stops the accelerator lever.
Cheers
Aug 19, 2008 | 1996 Toyota Land Cruiser
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
