Question about Denon POA-3012CI 12-Channel Amplifier
I have blinking lights on the zone indicator. What does this mean
    Genius:
  • 1,175 Answers
Do you have speakers connected to that "Zone"?
If not , that's the problem
Posted on Aug 17, 2010
Hello I have a 2007 dodge magnum 2.7l my engine light started blinking and car is shaking what could it be? I took it to auto zone and had my codes read which is in the picture.
You have an engine misfire and I can't read the picture, the code indicates the cylinder that is misfiring, for instance a P0302 means cylinder #2 is the problem cylinder. As to the cause it can be a lot of things.
Sep 28, 2016 | Dodge Cars & Trucks
Tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
on Mar 31, 2011 | Office Equipment & Supplies
My explorer sport 20002 has a blinking light (o/d off) what could be the cause I'm having problems with the transmission after that.
I suspect that you are referring to the transmission speed sensor light. This light goes on to indicate that the transmission is faulty due to a broken gear or something else like the differential. Check the attached link for more details. Vehicle Speed Sensor Description Related Information So what exactly is...
Feb 02, 2015 | Ford Explorer Cars & Trucks
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
My malfunction indicator light of my Toyota camry 2000 is blinking and the car cannot accelerate well. my mechanic seems not to understand the problem. what ca I do?
When you said "...indicator light blinking," I assume you mean "check engine" light is on. Procure a check engine code reader and download the trouble code. When you isolate which component the trouble code is talking about, ascertain its not a faulty sensor. Read the code reader instruction and look up "clear trouble code" to turn off the "check engine" light. Replace the sensor first and see if it stops sending the trouble code. If the sensor is still sending a trouble code (check engine lights up again), then replace the component which the sensor is monitoring.
Nov 29, 2013 | 2007 Volkswagen Jetta 2.5 Sedan
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Tc-p50g20 4 blinks
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Diagnostic light blinking 17 times means what ?
i had the same problem, it should be the speed sensor on your transmisson after a while your speedometer will stop working. no clue on the lamp...
Dec 29, 2008 | 1989 Honda Prelude
Denon POA-3012CI 12-Channel Amplifier Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
