Question about Xerox C2424 Copier
Jam c3t 15747 is indicated on the machin jan count whats the cause
    President:
  • 2,072 Answers
If the Jam code is C3T, ensure the process drive assembly is correctly homed. 4. Ensure the stripper carriage moves freely 5. Run the transfix drive slow and transfix drive fast test.
Posted on Jul 23, 2010
What would make the water in the bowl not fill to the normal level at times? Could heavy rain field lines cause this vaccum?
Why Is There Low Water Level In The Toilet Bowl And How ...
? 4:37
https://www.youtube.com/watch?v=UhVpipC0BEw
Jan 17, 2015 - Uploaded by MrKistel
Why Is There Low Water Level In The Toilet Bowl And How toRepair ... Sign in to make your opinion count ...
Nov 19, 2015 | Home
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
My Xerox Phaser 8560N has paper jams very often. The codes from Troubleshooting->Service Tools->Jam History for the last 20 jams are: - N4W [9] - C3T [6] - P4V [2] - C3X [1] - M4F [1] -A2C ...
Most of these types of paper jam errors are caused by a cracked cam on the Drum Maintenance Camshaft, which throws the timing off for the whole print process. I would recommend a technician replace the camshaft because there are components that need carefully removed to avoid breaking, then they need to be properly aligned and timed when they are reinstalled. Not really a do-it-yourself repair.
Aug 29, 2013 | Xerox Phaser 8560N Laser Printer
How do I find out how many pages are on the current drum in my Brother 2820 machine
You must enter in maintenance mode:
Press the Menu/Set and Start keys. Next press the key four times to make the machine enter
the maintenance mode, or turn on the machine while pressing the menu/set key.
The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the
machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80)
Function
The equipment may display its log information on the LCD.
Operating Procedure
(1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
The USB serial number appears on the LCD.
(2) Press the Start key. Each time the Start key is pressed, one of the following log
information items appears on the LCD in the order given below.
1) Jam count, indicating how many times a paper jam has been occurred
2) Page count, indicating how many pages the photosensitive drum has been printed
3) Total page count, indicating how many pages the equipment has been printed since
produced
4) Drum count, indicating how many times the photosensitive drum has been rotated
5) Drum change count, indicating how many times drum replacement has been made
6) Toner change count, indicating how many times toner replacement has been made
7) Copy page count, indicating how many copies have been made
8) PC print page count, indicating how many pages the equipment has been printed as
an output device of the connected PC
9) FAX page count, indicating how many received FAX pages have been printed
10) Error code of the most recent machine error *1
11) Error code of the most recent communications error *2
12) ADF jam count, indicating how many times a document jam has been occurred
13) ADF page count, indicating how many documents have been fed
(3) To stop this operation and return to the equipment to the initial stage of the maintenance
mode, press the Stop/Exit key
To exit maintenance mode press 99
Mar 07, 2011 | Brother IntelliFax-2820 Laser Fax
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
I have Xerox 8550 coming up with a jam when the printer starts up. The C3T error code is given. Today I opened it up and following the instructions from the Service Manual I did the homing procedures on...
Two things normally cause that. Look in the area inside the top cover where there are 2 green guides that flip up so you can clear a jam off the drum. See if the clear mylar guide it bent or cut causing the jam.
If that is ok then more than likely you have a process drive timing problem. That is the drive gear assembly on the right side of the machine.
You can try removing it and retiming it by inerting pins throught the timing holes.
I suspect a process Drive timing problem
Mar 01, 2010 | Xerox Phaser 8500/DN Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
The first symbol with the two circles and the paper one are both flashing. thanks
This can be caused by a paperjam somewhere in the machine. Examen your machine to see if there is a piece of paper jammed in your machine. If you are sure there is no paper in the machine the formatter board can also cause this problem. In that case you'll have to exchange your formatterboard. Partnumber Q7805-69003. Gerrit Jan
Nov 09, 2009 | HP LaserJet P2015dn Printer
Error caused by paper jam - but there's no paper jam
the carriage (carriage stalled) in jammed in the right side of the all in one, try slowly free it, also check cartridge status.
(carriage stalled in process of cartridge cleaning)
May 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Xerox C2424 Copier Logo
192 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
