Question about HP Computers & Internet
My husband has some how adjusted the settings on the monitor to now be out of input range. Screen is black - cannot seem to change settings back. How do we do that?
  • horsewiser Jul 23, 2010
    Didn't get an answer from the last person so not spending any more money to try again. Goodbye and thanks for nothing!
    Genius:
  • 1,478 Answers
  1. Click the Windows START button in the lower right hand corner of the screen.
  2. From the menu, choose SETTINGS and then CONTROL PANEL.
  3. The Control Panel window opens. Click the DISPLAY icon.
  4. The DISPLAY PROPERTIES dialog box opens. Click the SETTINGS tab.
  5. In the SCREEN AREA box, use the slider to adjust the monitor settings. Towards LESS will make everything on the screen bigger; towards MORE will make everything on the screen smaller.
  6. Click the APPLY button. The Display Properties message box opens, announcing a fifteen second delay before the changes take effect. If you would like to continue, either wait or click OK.
Take care.
Posted on Jul 23, 2010
    No. None of what you suggest was possible because I could not get to a start menu.
    I needed a DOS prompt which I found.
    My problem has been solved so please close this request. Thank you.
    Guru:
  • 731 Answers
What is the model of your Monitor, each manufacturer has thier own settings,
Posted on Jul 22, 2010
  • 4 more comments
    W2007
    W2007 HP
    Is this not the correct information? How long does it take to answer usually?
  • Mohammed Rizwan
    Mohammed Rizwan Jul 23, 2010
    Does it says "Input Signal Out of Range" ??
    Yes it does.
    I would have assumed an answer would have been a bit speedier.
    I feel like I wasted my money here and will never use this services again.
Monitor is in slef adjust mode how can i turn it off
It seems like graphics resoluation setting is changed and is beyond the range your monitor can support, what colour is the power light of monitor? as there is no model of the monitor, I can recommend to connect a bit newer version of monitor and see if the screen is on, if not then it will be graphics card settings.
Nov 13, 2012 | Dell Dimension 2400 PC Desktop
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
Just installed a ZR24W monitor, screen blacks out after 10 minutes with a message saying 'Input signal out of range, change settings to 1920x1200-60hz'. The monitor was set to this resolution &...
You will need to adjust the refresh rate of your system.
1) Right click on the desktop and go to properties.
2) When the Display Properties window opens go to the Settings tab.
3) The go Advanced.
4) Once ni the advanced screen go to the Monitor tab.
5) Under screen refresh rate select around 60Hertz. (Make sure the box next to "Hide modes that this monitor cannot display" is ticked.
6) The click OK. And OK again to exit Display Properties.
May 26, 2011 | HP Smart Buy ZR24W LCD Monitor
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Input signal out of range......my problem...hp w1707
your video card setting may not be compatible with your monitor's capability. you may need to reduce the screen resolution. you need to boot up on safe mode to change this or use another monitor for a while and try to adjust the screen resolution.
Oct 07, 2010 | HP W1707 LCD Monitor
After Windows has started and the setup screens show, my Kogi monitor says "out of range" and the screen goes black. How can I fix this?
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
Sep 06, 2009 | Computers & Internet
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Input Signal Out Of Range
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
