Question about Royal 10X Shredder
How do you empty royal 10x shredder? PX1000MS Platinum
    Genius:
  • 1,218 Answers
Remove the waste bin from the front and empty.
If you have it jammed so full the bin wont come out I have heard people say that they got the bin out when they turned the machine upside-down....be aware this might make a mess.
Posted on Oct 07, 2010
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
I have a Royal 10X Shredder. It should shred up to 10 sheets but if I put more than 1, it gets jammed. Is it an oil problem and if so, where do you put the oil?
Try putting shredder oil on the 1 sheet that will go thro'....do this a number of times until you get things free'd up and it starts to take more sheets. Put the oil on the sheet in an "S" pattern.
Jul 05, 2011 | Royal 10X Shredder
Need a gear
Give Royal a call at 1-800-524-0799 they should be able to help.
Aug 15, 2010 | Royal 10X Shredder
Locked up
If the shredder jammed due to too much paper and now won't go fwd or back then you have likely lost the pcb in the machine...call Royal at 1-800-524-0799 for availability and prices.
Jun 09, 2010 | Royal 10X Shredder
How do I unblock my
Try running it in reverse..if that wont clear the paper jammed then it will hav to be taken apart.
Apr 04, 2009 | Royal 10X Shredder
Royal 10X PCUA 29054E, the gear appears to come off/brok
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 16, 2009 | Royal 10X Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
Royal 10X Shredder Logo
211 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
