Question about Lexmark X5470 All-In-One InkJet Printer
How do i adjust the control panel on the front of my x5410. i lifted it up to check cartridges and now i can't get it down back in place.
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow to download the user guide of the printer ,and to know the adjustment set up of the front cover that you are asking about….
http://safemanuals.com/annexe_SETUP%20SHEET_LEXMARK_X5410-_E.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 22, 2010
I have a brothermfc 7340 printer and cannot replace the drum
Open the front of the printer by pulling the front panel toward you and down. (where you replace the toner cartridge)
Remove the toner cartridge/drum unit assembly by pulling up and toward you.
separate the drum unit from the toner cartridge by pressing the green release tab on the side and lifting them apart.
place the toner cartridge into the new drum unit
replace back in the printer
press "clear/back" button and then press "1" to cancel "replace drum" message
close the front panel.
http://support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=mfc7340_us_as&faqid=faq00000154_039
Apr 04, 2015 | Brother DCP Office Equipment & Supplies
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
Load ink cartridges
Lift top lid, then scanner plate. Cartidges should automatically move to position. Gently push down on front of old cartridge to release it. Peel plastic tab frm back of new one(s). Put new cartridge in with front at downard angle. Lift front until new one snaps into place. Close lids.
Hope this helps
Dec 04, 2010 | Canon PIXMA MP210 InkJet Printer
One page paper jam on model 5650
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 12, 2010 | Office Equipment & Supplies
False paper jam message
Check the following Steps to Fix Hp printer carriage jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 29, 2010 | Office Equipment & Supplies
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    Where is the catridge of pixma mp 240
    easy one.. open the front of the printer, where the paper comes out. Place your thumb under the lip of the printer just under the name Canon and lift. The top of the printer will lift up and lock into place when you lift it high enough. Do this with the printer turned on and the cartridges will slide out from the right into the middle for easier replacement. If you do this and the printer is turned off, the cartridges are hidden from view as they are parked on the rest stand underneath the front panel buttons. Press the grey cartridge release towards the front of the printer and the cartridge enclosure will open, remove the cartridge, refit the new one (or the old one), close the enclosure cover and then drop the top cover by pushing the support leg towards the back of the printer as you lower the top. Then go into control panel, printers and scanners and right click on the printer icon. Select properties, then select the maintainence tab. click on the printer alignment and follow the procedure.. Done..
    Oct 31, 2009 | Canon PIXMA MP240 All-In-One InkJet...
    E-90 error message on Epson CX6000
    If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
    If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
    1. Turn off the Stylus CX.
    2. Lift up the scanner.
    3. Press down on the ink cartridge cover to make sure it is completely closed.
    4. Close the scanner and turn the Stylus CX back on.
    Also
    If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
    2. Lift up the scanner to access the printer area.
    3. Remove the tape from the ink cartridge holder.
    5. Close the scanner.
    6. Turn the Stylus CX back on.
    Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    The catridges are put in correct places,but when i give a print
    I had that problem with my Lexmark X5410. The cartridge box
    said it worked in the X5410 but the instructions gave a different
    number cartridge to use. The #32 cartridge was not right for my computer. It needed a #28 Black.
    Also - make sure you remove the tape from the cartridge before installing it.
    Good luck
    Jan 17, 2009 | HP Officejet 4355 All-In-One InkJet...
    HOW TO CHANGE INK CARTRIDGE ON A MP220
    open the whole cover of the printer (look in the front part just below where is written cannon lift it up). you will find the instructions on how to change inside. keep the printer on.
    Sep 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
    Lexmark X5470 All-In-One InkJet Printer Logo
    48 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
