Question about Panasonic Lumix DMC-TS1 / DMC-FT1 Digital Camera
After snorkeling camera wont work at all
Checked all doors were shut properly and went snorkleing now camera wont turn on at all. charged the battery, removed memory card, recharged battery, no luck please help.
  • 36 Answers
The sad saga of buggered u/w cameras continues. Check the interior of your camera carefully for any sigh of salt which will look like white crusty deposits or resulting corrosion. If you find same, it a major repair or toss the camera. One must be *extremely* careful when cleaning the seals and closing up an underwater camera. The slightest contamination on the seals such as lint, a hair, a grain of sand or whatever, is all it takes.
Consider cameras used on or around or under salt water as an expendable item. Harsh but true in my long experience in U/W
photography. Was NOT much of a problem with w/ film cameras, but the modern electronic wonders are very delicate.
Posted on Aug 20, 2010
Runs really good with out snorkels but boggs out with snorkels. What could cause it to bog out with snorkles? Maybe rejetting? If so which size? It's stock that I have now l
Sounds like your snorkels are restricking air flow big time. You can try going with smaller jets but your performance will suffer. Larger or more snorkels would be the answer if you have to have them. Try to have as few bends as possible and keep checking them to make sure each of them are clear.
Feb 22, 2016 | ATVs
The clasp to connect mask to snorkle broke. can I purchase the small clasp?
In short, no. But just do as many other do and use a short rubber band. Lay the middle of the band across the inside of the strap, and then pass the snorkel tube through the two resulting loops either side of the strap.
May 21, 2010 | Speedo Condor Mask Snorkel Set
I went snorkeling with my olympus 780sw camera last weekend and was taking photos just fine. It was nearing the end of the battery life I believe and when i went to try to turn it on, nothing happened so I...
I have the same problem with my 770 SW. The funny thing is, some outlets in my house will allow it to charge, some will just make the light flash. I found your question looking for a better solution. Try all the outlets in your house with the charger, I know it sounds silly, but it works for me.
Mar 05, 2010 | Olympus Stylus 790SW Digital Camera
Lumix dmc-ts1 will not turn on after taking underwater pictures
I had the same problem, half way through snorkelling the screen just went black and the camera wouldnt turn back on, HELP PLEASE!!!
Nov 27, 2009 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
Camera wont turn on
try to check the battery contacts of the camera...you might need to 'wipe' a contact cleaner to clean it. Caution: Be careful on working with chemicals with your camera. If still no luck...refer to a qualified service tech
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
Clearing the Snorkel of Water
Step1 Make sure you are gripping the mouthpiece of the snorkel securely with your teeth. Step2 Exhale forcefully through your mouth. The majority of the water should be expelled from the tube. This method is commonly called "blasting" or "popping." Step3 Inhale gently at first in case there is any residual water. Blast a second time if needed. Step4 Continue blasting whenever water enters the snorkel.
Dec 01, 2008 | Aeris Snorkeling Bag
Wont turn on
check out if the battery is fully charged.and even if the battery is very old it does not get charged completely so replace the battery and checkout it should work.
Aug 30, 2008 | Samsung Digimax L830 Digital Camera
790SW Problems
my camera is doing the same thing... i will let me view pix but not take them =( loved the camera took it to maui and even went cliff diving with it.. worked fine until one day i took it snorkeling and a little water got in. worked for a while after that only the screen fogged up and now i have the problem of not being able to take photos
Jun 01, 2008 | Olympus Stylus 790SW Digital Camera
Panasonic Lumix DMC-TS1 / DMC-FT1 Digital Camera Logo
193 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
