Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Icicles in Freezer
There are icicles forming in my freezer. It looks like there might be water collecting on the ceiling of the freezer and causing it to freeze throughout the racks. Ice is on all food items and it's on all the shelves.what could cause this problem?
It is on the recommended setting for temperature, and it happened over night last night. Any Ideas???
    Problem Solver:
  • 5 Answers
Yes.because if you not go down the temperature there will be icicles formed so keep your freezer in the right temperature
Posted on Jul 23, 2010
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Icicles in freezer compartment
you can do the dollar check to see if indeed the gasket is the problem,thats what it sounds like. close dollar in door and pull out slowly,you should feel some resistance.also at the top corner of door you will find 3 screws at the hinge, loosen the screws a couple of turns and you will be able to adjust the fit of the door ,move it alittle to make sure it is square with the fridge,this may help then re-tighten screws.
Aug 14, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is overflowing and causing icicles in Kitchenaid KSRS25IHSS02 side by side refrigerator. Trying to find location of water flow adjustment set screw.
The adjustment screw is under the cover on the front of the icemaker...it is only a very small adjustment and by adjusting it very likely it will have no bearing on stopping the icicles from forming on the i/m but instead what the problem is,is the water inlet valve is not fully closing. This tip i wrote covers the problem with the water valve and why its causing icicles in the freezer.
http://www1.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
GENE
Sep 28, 2011 | KitchenAid Superba Architect KSCS25INSS...
Inside the freezer has bunch of icicles and the freezer temperature fluctuate and it does not stay constant?
Your evaporator fan motor might be bad. This causes the icicles. Listen for the fan motor turning next time, you may want to hold down door switch.
Rich
Western Appliance Repair Boise id
Dec 02, 2010 | Jenn-Air Refrigerators
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Why icicles are formed at the outlet of the icemaker?
  1. this is normally caused by warm air getting into freezer
  2. check door gasket
  3. check dispenser door is shutting completely
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer Door
Defrost to get rid of icicles (temporarily). shut the door on a piece of paper , and try to pull it out . The gasket should be tight enough with the door closed that the paper will resist being pulled out, or not come out at all. Check all around the door, it might be bad in just a small area. A bad gasket means warm air enters, cold are exits, and where the two meet, condensation forms, which inside become stalagtites (I mean icicles). The service guy should have checked it, but hey, who would expect a new appliance not to work properly? If the gasket checks out ok, maybe insulation was not installed properly in the door, which would cause temp variation. countrycurt0
Aug 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
566 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
