Question about John Deere Garden
Fuel starvation problem on Kohler 16 HP engine.
I have a Scotts riding lawn tractor, model S1642, with a Kohler 16 HP engine. A year ago while mowing (engine hot), every time I went up even a very slight incline(not any hills), the engine would sputter and die as if starved for gas(unless I got the tractor headed down hill). I went to a John Deere dealer parts desk and was told that the small solenoid on the bottom of the float bowl needed to be replaced. I bought a new one for 75 bucks, replaced it, and am again having the same problem. I would appreciate any help in solving the engine problem. Thanks...Zeibart
  • 1,906 Answers
Replace the fuel filter
Posted on Jul 22, 2010
    President:
  • 2,702 Answers
This solenoid is for the fule level in the carb if its not working right it starves the engine of gas (petrol) so you will need to change it to get the motor running right,,,you could try cleaning the solenoid in switch cleaner first,,take it out and soke it in a tin of switch cleaner it may get it going again but dont hold your breath that this will work
  • hockey 99 Sep 30, 2010
    Had the same problem with my scotts 1642 . No gas in carb when riding flat .. First change the filter and try again , same problem, run for a while and die, no gas in filter, so put a longer hose between filter and carb and also between tank, took tank out and cleaned it and made sure filter was not horizontal , a little vertical because of gravity feeding and he has been running well since,. Answer is : don't know what fixed it, dirty tank, longer hose to keep filter vertical and keep air bubble out of filter or just luck, but worked 3 days in row with no problem.
Uneven mowing
make sure the belt sits level there is adjustments for each side
Aug 20, 2012 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a husqvarna YTH150 hydrostatic kohler motor 1995-1999 upon starting it takes many tries then when started its like its on a steady idle it'll idle high then low in a steady rotation until it cuts...
Sounds like fuel starvation, clean the fuel filter and lines, make sure there's no muck in the fuel tank. It's also possible the choke is sticking, although the exhaust would smoke and smell of petrol (gasoline).
Aug 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas is mixing with oil
I had this happen to my tractor several years ago. Turned out since the fuel is gravity feed, the fuel would syphon into the engine after a time. I took a zip strap and looped it around the fuel line loosely and attached it to higher part of the cowling, to put a slight HILL if you will in the line to break up the syphon effect. Worked great no further problems with that. Mine is a 1996 craftsman lawn tractor 42' deck 15.5 HP briggs. Been a work horse for years, but as of a week ago "issues" with tranaxle.
hope this works for you.
Happy mowing.
Maggies Mom
Jun 06, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
What weight oil should I use for 16 horsepower craftsman engine?
It all depends on the engine you have...all engines except for KOHLER can use straight 30 and Kohler uses only 10W30.
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
1,792 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
