Question about Kenmore Sewing Machines
How to thread and operate a kenmore serger #1564180 there is no owners manual.
  • Anonymous Mar 15, 2014
    IKenmore 16655100 am looking for the owners manual for my serger
  • Kenmore Master
  • 7,365 Answers
Try sites for manuals
sew usa
sewing manuals.com
ebay
Posted on Jul 30, 2010
How to thread for flatlock serging
It would help if we knew what machine you have.
Serger Sewing How to Sew 2 Thread Flatlock
Flatlocking made easy Serger Pepper
Choose the Right Serger Stitch for Your Project Threads
Your owner's manual should have specifics on how to set up your machine.
Jan 25, 2018 | Sewing Machines
I need a manual for a Kenmore Serger Model #385-1564180
Sears carries manuals for most of their machines.
May 31, 2017 | Kenmore Sewing Machines
Why does lower looper keep breaking
probably need a adjustment, you may have to have the looper checked
May 26, 2016 | Sewing Machines
Instructions on changing thread tensions on a Mylock134
Probably the best thing would be to consult the owner's manual.
BEFORE you thread the serger, RAISE the presser foot so the threads will seat properly and the thread will slide easily. Be sure to thread each thread in the proper ORDER! (Usually upper looper is first, lower looper second and the thread tail should always end up laying OVER the top of the upper looper before passing under the presser foot.)
It is also helpful to use different colors of thread so it is easier to tell which thread's tension needs adjustment.
Sergers require varying tension settings depending on the type of stitch and the appearance you prefer. To achieve the standard stitch setting on most sergers, start out with all the thread tension settings at the midway mark between the high and low numbers. Then test and adjust from there.
Verify with the owner's manual that you are threading everything correctly and not missing any steps. If any thread happens to break or come unthreaded, it is usually best to unthread EVERYTHING and start over from the beginning. (Sergers are very finicky, so if you are frustrated trying to get things to work, the last thing you will usually try is unthreading and rethreading from the beginning.)
The Secret to taming your Serger
Adjusting the Thread Tension on Your Serger PREVIEW BurdaStyle
Dec 06, 2015 | Sewing Machines
How do I thread my overlocker
If thread is breaking, it usually means it is threaded incorrectly--either you have missed a thread guide or have it looped somewhere it shouldn't be. The tension could also be too tight on that one thread.
RAISE the presser foot BEFORE threading!
Be sure you are threading each thread in the ORDER described in the owner's manual. Most machines are threaded in this order: 2nd thread from the right (upper looper), last thread on right (lower looper (this thread must cross over the top of the upper looper in the final step!!!), then the needles--but you must check your machine's manual for the correct order!
Confirm with your owner's manual that you are threading all the guides. If you miss one of the thread guides, your machine will most likely not operate.
Also, if you break a thread, it is strongly recommended that you remove ALL the threads and start over from the beginning. Sergers can be very finicky!
This video may help, although your machine may thread differently:
How to Thread Serger Overlock Machine
Oct 28, 2015 | Sewing Machines
When we thread the serger . the thread is still skipping
Are you using the corfect serger system needles in it? Most domestic sergers will take the regular domestic needle 130/705X but work best with a serger needle with has a groove down the front as well as the regular back scarf. This helps with the thread pickup from the looper by the needles. Sergers also run much faster than domestic sewing machines so the tolerances are very fine.
My Bernina came with ELX705 needles and it does run better with these in it. Also you need to use mid size needles, don't go too small, probably a size 80 or 90 is best.
Check out this page for some good info as the different serger manufacturers do have their own recommended needle sometimes. http://sewingmachine221sale.bizland.com/store/page78.html
Always refer to your manual (or ring the manufacturer if lost) to double check what needle they recommend be used in your serger, it does make a difference.
May 19, 2011 | Sewing Machines
I'm looking for Kenmore Serger Model # 16677 owner's manual.
Go to http://www.managemylife.com/mmh/owner_manuals/26810/KENMORE-Mechanical-Sewing-L0712571?brand_name_search=Serger+16677. It's the sight for Sears manuals. This is the original owner's manual available for download.
May 17, 2011 | Sewing Machines
I just changed my Kenmore serger's needle and it stopped making the overlock stitch. I rethreaded the machine twice and make sure the position of the needles is correct but it didn't help
Hi
If you have the operators manual for this serger, you should be able to follow the threading from the start successfully. Some machines have a better threading diagram on the machine itself.
The needles should have the groove facing the operator's position. They should also be fully inserted in their mounts. Most sergers do not release the thread tensions when the presser foot is raised, therefore, you must zero the tensions to make sure the threads are fully entered into the tensioners when threading anew. After threading, you must readjust your thread tensions to the desired tensions for the set-up you plan to use. Thread tensions should be recorded for each stitch set-up because each serger tends to be a bit different, and therefore, allows you to quickly adjust for the desired stitch needed. The different stitches are adjust and fine tuned by each individual thread tension.
Hope this helps
Ray
Dec 22, 2010 | Kenmore Sewing Machines
Problems With the Tension serger kenmore
Open the tensions (set at zero) and have the presser foot up when threading.
Make sure the antenna if fully extended.
Turn the handwheel so the upper looper is at it's highest position.
Thread, beginning at the right thread cone unless the manual indicates differently.
After threading, set the tensions back to the recommended setting.
If this does not help, please provide more details.
Mar 10, 2010 | Singer Tiny Serger TS380
The order in which to thread the serger
Your serger should be color coded for threading. Just do one at a time either left to right or right to left with the cones. And you should be all set.
Apr 19, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
218 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
