Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Does not clean dishes properly
Kitchenaid Model KUDI01FLSS3
My wife thinks the water level is staying too low and the washer does not spray the dishes properly. This just started the other day. The float seems to be free but the water level does not push the float all the way to the top.
I am not sure if the water is pumped for the spray or just relies on the water pressure to turn the spray. There does not seem to be anything on the screen just under the main spray.
Is there a filter on the water line that could be plugged? Is the water level controled by the float or a timer?
I will anxiously wait for your response
Thanks, Lyle Christian
5 Suggested Answers
lancer721
  • 229 Answers
SOURCE: My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Posted on Jan 18, 2009
  • 677 Answers
SOURCE: KitchenAid Superba KUDSO1FLSS3 Not Rinsing? No Cleaning at all!
the problem is hard water in your area. www.dishwasherfilter.com has a new product out that will solve this problem. it filters the water before it goes into your dishwasher. very affordable and works amazing. get it at www.dishwasherfilter.com.
Posted on Apr 02, 2009
localwonder
  • 6784 Answers
SOURCE: will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Posted on Jun 16, 2009
  • 949 Answers
SOURCE: Upper spray arm is not turning
Hi Chris,
It sounds to me like a restriction in the pump. I put together some information here on cleaning it out. If you try these please give me some feedback as to if they help or not.
Thanks!
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Kitchenaid dishwasher fills with hot water but doesn't wash
remove sump cover clean sump and change the chopper
Feb 21, 2014 | KitchenAid Dishwashers
Dishwasher does not clean dishes completely model # kudso3ftss3
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | KitchenAid Dishwashers
I have a built in whirlpool dishwasher. My problem is that dishes aren't being washed properly, there was water in the bottom of the washer, I removed and cleaned the filters ran the machine and the water...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not clean after they go through the washing cycle
Hi
Jan 24, 2011 | KitchenAid Dishwashers
Dishwasher not cleaning dishes properly
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
zzty
Jun 16, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
UPPER LEVEL SPRAY DOES NOT SPIN - UPPER LEVEL NOT
plugged spray arm holes, pump intake partially blocked, too little water getting in tub cuz screen in fill valve has debri
Dec 21, 2009 | KitchenAid KUDC25CH Dishwasher
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
73 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
