Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag side by side water/ice dispencer
I keep getting water beneath my fridge, a repairman showed me once how to clear the ice that builds up in the bottom tray by taking of the back panel bottom part only and clearing the ice build up at the bottom and making sure the water flows through before putting it all back together. Can anyone tell me why it builds up and how do I stop this, it's a pain to have to clear the freezer (good thing I have a second fridge downstairs) and wait for the ice to melt so the water pathway is free from ice.
  • 4 more comments
  • Anonymous Apr 29, 2008
    I have the same problem. There is a build up of ice in the bottom of the freezer even after I defrost i and the fridge leaks water near the front. I checked the ice maker to see if it was iced up and that is not the problem
  • Anonymous Jun 18, 2008
    Same problem...what gives? What is the solution?
  • FauldsRW Jul 13, 2008
    I have the same problem. I place paper towels under the icemaker in hopes it was excess water not going into the icemaker.
    No moisture from icemaker.
    I also placed paper towels below the slots in the back of the freezer, and sure enough the water is coming from behind the slotted panel.
    I suspect that inside the back panel (which is removable) is the self-defrosting mechanism with a drain line that is supposed to carry the water off into a tray in the bottom of the freezer where it is continually evaporated when the fridge is runnin.
    I will post again if I can confirm my suspicion.
    Roger W. Faulds
    Toms River, NJ
  • FauldsRW Jul 14, 2008
    Hello again, Roger here.
    I have compiled a PDF file that you can download that helps explain one reason why you have an ice buildup in the bottom of your MZD2766GE* Maytag and suggested steps that you can take to resolve it. Defrosting alone does not resolve the problem.
    The link is: http://www.yee-haaa.com/downloads/200807....
    It resolved my problem, I hope it resolves yours.Although it resolved mine this information is provided as a suggestion only and you assume full responsibility for following the directions. It is for your information with no express or implied warranty.
    Roger W. Faulds
    Toms River, NJ
  • Ling Shiao Oct 06, 2008
    I followed someone else's suggestion this morning by putting some hot water on the frozen ice in the drip pan. So far it's ok. My question is, where does these water go? Am I flooding something by pouring hot water in the drip pan?
  • Evansstuff Oct 20, 2008
    I have the same issue. I see the bottom of the freezed full of ice and water runs from the bottom inside out of the door and onto the wood floors. I have had repair men out numeorus times for this issue but after a few months, same issue again.
    Very poor engineering on this frig. It has literally ruined my wood floors because puddles of water would be on the floor in the morning when I get up to go to work. At least once a week this occurs.
  • 121 Answers
Sorry, mine does it also..bad engineering.
Posted on Apr 22, 2008
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water is not coming out of water dispencer and ice maker is not making ice also i just installed a new water filter
Have you checked the fitting that hooks your Refrigerator into your water system? This fitting is most usually located on the cold water feed for your kitchen sink. This fitting can get build up of calcium and other minerals from your water.
Nov 01, 2010 | Maytag MZD2766GES Side by Side...
The ice dispencer would produce ice
Dear Adriana, I have the exact problem. I have yet to find a clear solution to this problem. The temp in the freeze seems to oscillate too much, and the leaking water led to a damaged light in mine.
Have you discovered a solution? It was recommended by a repairman to replace the controller board for the unit. I have yet to implement this approach. Wondering what others have discovered.
Marco
Dec 06, 2009 | GE PSC25MSS Stainless Steel Side by Side...
Kenmore Fridge: 44103 side by side: I keep finding a
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Kenmore 44103 Side by Side Refrigerator
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Samsung fridge filter leaking
HI,
your drain is clogged.you may have a catch for your drain where you see leak coming from.that may pull off and you can see if their is trash build up in it.you are going to need to take the panel off the back of freezer.inside back of freezer you will see screws.they will need to come out,if you have ice maker that will need to be removed also.once back panel is off you will see your coils,beneath the coils it will most likely have a sheet of ice.tturn machine off and take a hair dryer and defrost the ice.once ice is gone take a cup of hot water and run thru drain to see if unclogged.repeat if drain is not clear.the ice in drain tube will eventually unclog.I use a steamer.much quicker.
thanks,
Mar 22, 2009 | Samsung Refrigerators
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag MZD2766GES Side by Side Refrigerator Logo
165 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
