How to configure a IDE computer belt. - Computers & Internet
  • nobertor97 Jul 26, 2010
    yes to some degree, now what's happening is diskette drive 0 seek failure, diskette drive 1 seek failure,
    PXE-E61 media test faulure,
    11-mof:exiting PXE
    Error 8602-Auxiliary Device failure. it reboots and show the welcome srceen, then it go's back to the top and show again diskette drive 0 seek failure
    and diskette drive 1 seek failure, it repeats it self over and over again.it's a 2000 intel, old but
    would like to fix to give to someone who may need a computer. thankyou.
  • 472 Answers
  1. Configure your jumpers for the drive's position. Your options are Cable Select (if your drive and computer support it), Master or Slave. If the drive will go on the end of the IDE ribbon cable, then it will be a Master; if it goes in the middle, it will be the Slave.
  2. Mount your IDE hard drive into a drive bay. Make sure you use all four screw spots so your drive can spin securely.
  3. Mount your IDE hard drive into a drive bay. Make sure you use all four screw spots so your drive can spin securely.
  4. Connect your power supply to the drive. IDE drives use a 4-pin power connector and any of them from the supply will work.
Note : you can also click on the link below to see few detailed instructions and photos on installing IDE cable. http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
Good Luck!
Posted on Jul 22, 2010
What is sata mode for this machine ide mode or ahci mode
AHCI (Advanced Host Configuration Interface) is a standard that defines SATA configuration. IDE mode is used when a host computer doesn't support sata drives. Every OS post Windows XP can handle ACHI or sata mode.
Apr 05, 2015 | Computers & Internet
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Will an IDE DVD Burner work on my Acer Aspire E380 desktop. The hard drive is a SATA but the burner looks like an IDE and has belt cables. I need to replace my DVD burner and not sure what type of burner...
Yes, all you need is a IDE (Pata) to IDE (Sata) converter.
If you're replacing it, just make sure you get one with the correct interface, judging by what you sat SATA.
Mar 13, 2010 | Acer Aspire E380-ED422A PC Desktop
IDE Connection to HDDs Problem
Check the IDE cable, Jumpers (Master/slave), power connector/cables, this will fix your problem if there's no internal damage on the motherboard. Good luck Thanks for using FixYa.
Jan 20, 2009 | MSI K9VGM-V Motherboard
Setup did not find any hard disk drive on your computer
Just look for the BIOS set up and I,m sure you will solve your problem, or plug the IDE cable properly...
Dec 21, 2008 | ASUS P5GD1-VM Motherboard
Bios problem
you need to go into bios and set the ide drives correctly.
May 18, 2008 | Intel Motherboard
Ml530
There are many configuration settings, although i personally would hunt down an SCSI hard disk, many will fit from many other models just like IDE ones
Mar 24, 2008 | Compaq ProLiant ML530 Server
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
Motherboard does not have a SATA configuration on bios setup
use third party raid driver.use floppy drive for installation third party raid driver.
Sep 08, 2007 | Asrock P4VM8 Motherboard
Computers & Internet Logo
15 people viewed this question
Alun Cox
David Payne
David Payne
