Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon ip 4300
Paper pulls right side first wont feed
Google "canon ip4300". The canon.com entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Posted on May 04, 2008
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
MP150 paper feed not working on left hand side
Check your paper feeding roller, first clean them
Apr 30, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
I have a Canon ip 4300. Recently I had a paper jamb (81/2 X 11)
it maybe the sensers which tell the faults has moved out of position or wires loose
Jul 06, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon pixma ip 1600. paper feed mechanism faulty. will not grab paper and feed through or takes it through at an angle
You said that the paper is fed on one side. Am I right?. If it so,it seems that another material is present inside your printer.
Please check this post for more information
Nov 29, 2009 | Office Equipment & Supplies
My ip 4300 has stopped feeding paper
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 18, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma iP 1500 is not feeding paper correctly, pulling it on the right side but not on the left.
If the feed roller in the back wobbles a lot, the end could be broken, but usually I find that something has fallen in the back stopping the paper. The best way to look for something fallen in is to use a flashlight and small mirror.
Jul 12, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Paper wont feed propaly
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
May 26, 2009 | Canon PIXMA MP520 InkJet Printer
Set for type of paper on printer
right click go to properties of the printer and choose paper type
Jan 24, 2009 | Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
224 people viewed this question
old marine
old marine
