Question about Remington Precision HC-8017 Hair Trimmer
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it might be the blade not set properly. Is there a way that I can get a diagram on how to put it together? Or do you have any idea's? We have only had it for about a year and don't use it often. It shouldn't be broken yet or I bought a piece of junk and seriously will never buy another remington again in my life. Tell me that it's a simple solution.
    Top Expert:
  • Remington Master
  • 53,736 Answers
There is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
Posted on May 04, 2017
  • 62 Answers
SOURCE: Hair Clippers not clipping
All clipper/trimmer blades must be oiled both before and after use. Hold the unit with the blades pointed toward the floor. Put a dab of oil across the front of the blades and turn the unit on to get the oil distributed through the entire blade. Turn the unit off and wipe the blades with a soft cloth to remove any excess oil.
Posted on Jan 07, 2008
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
  • 6 Answers
SOURCE: Clippers jam and won't cut when trying to use attachments
I know it sounds simple, but have you tried a good sharpening.
Posted on Aug 15, 2009
brector3
  • 1632 Answers
SOURCE: The clipper blade adjustment on my Remington Hair
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at shaveroutlet.com
Posted on Jan 26, 2010
Testimonial: "Thanks "
SOURCE: Remington HC-921 Mens Clipper Kit Pulling hair not cutting
no but I can't wait until someone does- having same problem. They worked fine then didn't
Posted on Apr 26, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Wahl clippers
The clipper was being held at too sharp of an angle
Oct 01, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Mar 29, 2009 | Remington Health & Beauty
Oster Golden A5 Clippers will not cut
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
Feb 28, 2009 | Oster Golden A5 1-Speed Universal Motor...
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Remington Precision HC-8017 Hair Trimmer Logo
146 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
