Question about Cameras
I have a Philips older tv model # 27PS50B121 but do not have the manuel. The remote for it is RC19038001/01. What do the colored buttons on the remote mean? If you press the "happy face" button it says to press one of the colored buttons either red green yellow or blue. i am wondering if you have a user's manuel for both the tv and the remote? Thank you.
ctf1800
  • 4402 Answers
SOURCE: no red or green (only blue, yellow) in picture
need make and model
Posted on Dec 15, 2007
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
rylee_smith
  • 8619 Answers
SOURCE: what are the red green blue n yellow buttons on
Hi!
With the controls on the machines themselves pared down to the barest minimum, and virtually every operational setting done through software, and more interactive content being developed, the remote control is an even more crucial tool. Sony’s remote has a logical, well-designed layout. Along with many of the common features from DVD-Video remote controls of Audio, Subtitle, Angle and Display, the S350’s remote adds special buttons for the Pop Up Menu, Options and Scene Search. It also includes a group of Red, Green, Blue and Yellow buttons just above the navigation wheel in the center, which can be programmed for special functions by title authors. They are also used like Shift and Control keys on a computer keyboard when using the remote to enter text and number information. Green has become the default for setting Book Marks, but this, Scene Search and many other features are authoring choices, not necessarily standard on all titles. Perform functions assigned to each button. Assigned functions vary depending on the content being played.
You may also refer to the following web site---
Sony PS3
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 12, 2009
SOURCE: codes for durabrand tv with philips universal remote
I have a Durabrand TV and a Phillips universal remote... does any one know what codes i can use???
Posted on Aug 12, 2009
BillB-SA
  • 2761 Answers
SOURCE: when switched on, indicator light shows green then
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Posted on Sep 19, 2009
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    I have a philips universal remote and a ge tv but i dont have the manuel to the remote so i can set up my tv.
    Which model of the Philips remote do you have? Many of the remote codes are listed here: http://www.urc.philips.com/ (enter your language/country choice and click on the arrow). Then narrow down the list to your remote. The page will include a pdf of the manual as well as a code search tool.
    Please note that some universal remotes will not handle all of the features of a given model. If the TV was built ~6 months before the remote was programmed or is newer than that, the remote may not have a code that will work.
    I hope this helps.
    Sep 05, 2010 | Audio Players & Recorders
    Lost my remote for model 20MS2331/17. can I use a multi brand remote?
    Yes, but all depends on the exact model of the remote - newer ones no longer support the codes for older devices so make sure you get one that it's an older model. Or get a Philips universal remote.
    Aug 29, 2010 | Philips Magnavox 27MS343S 27" TV
    Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
    Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
    Apr 23, 2010 | Philips Magnavox Learning Universal Remote
    Will not turn on with remot and turn on button is
    Is there a way you can power it on, by pressing hard on the button? The get a new Universal remote and program the TV.
    Otherwise, it might be time to get a new TV.
    Feb 03, 2010 | Philips Magnavox 20MC4304 20 in....
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    New settings on tv remotes
    Hello Slffvo:
    Here are a few web sites that may help you out.
    http://www.hifi-remote.com/ofa/devices-tv.shtml
    http://www.universal-remote.net/philipsmagnavox.html
    Aug 14, 2008 | Philips Magnavox Learning Universal Remote
    Repairing color television philips
    Some tv's let you select menu from the buttons on the tv,on of the buttons will say menu and the volume and channel buttos will have a double function like an arrow to the right and left and arrow up and down,they also have a buttos that says select,press menu and use the others buttos to move thru the menus until you get to the color bar,if it is at minimum adjust it so you get your color back but if it is already in the middle the tv needs to be service.Philips sells universal remote controls that are already program to work your tv being a philips and you dont have to programe it and you can also access the menu.
    Oct 02, 2006 | Abt Television ABT IJETABT01 WIRELESS RF...
    Cameras Logo
    209 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
