Question about Car Audio & Video
PLCDCS90 Casette/cd I did notice there is a conflict between the diagram on the back of the unit and the trouble shooting tips in the manual. The manual says the player uses a 15A fuse, while the diagram (also shown in your post) says to use a 10A fuse. Thought that was a little weird. So you think maybe it should be a 15A?
  • chunter1989
    chunter1989 Apr 22, 2008
    I have a manual, but not in front of me. I specifically remember it saying to replace the 15A fuse if there is no power.
    However, the fuse filter shows there is a .5A and a 10A fuse. Filaments are both intact, and I've even tried new fuses.
    Is there a 15A internal
    fuse or is something? If not, they've mislabeled the diagram shown on
    the head unit. Same diagram as the one you posted earlier.
  • chunter1989
    chunter1989 Apr 30, 2008
    I tried a new 15A fuse. (fit perfectly) Also tried a new 10A as well, with no success. I also connected the power directly to the battery terminal, just in case my wire harness adapter is bad. Still no juice.
    Any other ideas?
    Thanks,
    Chris
    Brigadier General:
  • 3,614 Answers
It is 15A...
Posted on Apr 22, 2008
  • 1 more comment
  • micromaster
    micromaster Apr 22, 2008
    you got a manual with you..?
  • micromaster
    15A can also works for it. as long it is fitted to the fuse slot.
  • micromaster
    micromaster May 02, 2008
    well my idea is up for me now.., eh?
Need the schematic diagram for a Db drive A8 1750.1d
Victor, unable to locate schematic, links below are a manual with trouble shooting and db's web site to get customer support.
press the helpful button and follow me on fixya for more tips and info
http://dbdrive.net/wp-content/uploads/2013/09/A8-Amplifier-Manual-1_21_13.pdf
http://dbdrive.net/
Feb 14, 2016 | DB Drive Car Audio & Video
Jetta 3 1995 1.8,mortor does not turn which makes the car not to start. What can I do
There are som trouble shooting tips here:
http://www.fixya.com/cars/r5605161-trouble_shooting_isuzu_starter
Have a look at the first diagram, then follow the "General trouble shooting" section. Once done and you're still not sorted, get back to me.
Aug 24, 2010 | 1995 Volkswagen Jetta
Freezer cooling doesn't come on, just the fan comes on. please advice. thanks
http://www.master-bilt.com/pdfs/io_manuals/gt_50_60_80_io-2-21-07.pdf
Go to this web site and get the manual for your freezer. check out the trouble shooting section and the wiring diagram for your unit. If you are still having troubles, get back to me.
Jan 22, 2010 | Master Bilt 25.5 cu. ft. Freezer GT80
Need a manual for a goodman
An owners manual will only tell you when to and not to operate the out door ac. And give you some maintenance tips.
A technical manual will have a wire diagram maybe a mollier diagram or other diagram for recommended pressures and temperatures and maybe some trouble shooting tips (but not likely) on things like checking power in and thermostat settings.
If you need anything in particular please be specific about your trouble and post it. If you post back with more trouble I'll try to help you more.
If this helps you please rate me as high as possible.
Thank you for using fix ya and GOOD LUCK!
Mar 27, 2009 | Goodman Heating & Cooling
Stuck CD cassette
Dear needhelp5246,
What you need is a screw driver not a sledgehammer. Open the bottom plate of the system and eject the cd magazine manually. Hope this solve your problem.
ramesh22
Jun 14, 2008 | Bose Lifestyle 30 System
Nec vl350 usb not working in vista
Hi, First of all check that the usb is compatiable for your pc and the os.Check your installation and trouble shooting manual.
Or try connecting it to some other pc running vista.
check the device manager for the usb port and is active.
Install the device driver from cd if provided.Check the hardware for physical connections or any IO conflicts.Finally also try that usb is enabled in CMOS setup an make it to auto mode.
More troubleshooting tips if not solved, all the best
Anand.
Jun 11, 2008 | NEC Computers & Internet
98 Deville casette/radio stereo won't play after swapping to CD/Casette/radio
Since the replacement is a different one from the one you are replacing, the car wiring harness is probably different from the one needed for the new radio. This is a really important difference if the new one is part of a Bose system and that is not the option installed in your car. The best way to check is for you to identify the option codes for each radio and go to alldatadiy.com and compare the wiring diagrams.
Apr 16, 2017 | 1998 Cadillac DeVille
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
