Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Loud noise in freezer
The fridge is only 3 years only
    President:
  • 1,218 Answers
Good day,
Should not be too hard to resolve. If it has an ice maker you will have to remove it first. 3 screws and a wire plug.
Then remove the back panel. Most likely the fan motor is where the problem is.
Either the blades are hitting a piece of ice, which needs to be melted out. Be careful if using heat since most items are plastic and melt easily.
If not, then the blade pressed onto the motor has one of it's blades broken or the motor itself has a bad bearing.
If so, the motor is not repairable and must be replaced with a new one. Most appliance parts houses carry them, and it would be wise to buy a new blade at the same time.
Ordinary hand tools are all that are needed and it is a simple nuts and bolts repair.
Posted on Jul 22, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
We have the same noise. It has been lke this for about 2 years
Sounds like the fan motor in the freezer is too loose (armature bushing).Replaceing the motor should stop the noise .
Aug 09, 2009 | Frigidaire FRT21P5A Top Freezer...
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
75 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
