Question about Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50
This switch to a 1hp sewing machine motot
I need to know if i can hook this switchup to a 1hp motor it only has 2 wires coming out of it and the switch has 3
    President:
  • 2,030 Answers
Not you cannot...the switch is not rated to handle the cicuit load, it is only designed to handle the load of a lighting circuit, and you will overload it, and either blow the circuit breaker(or fuse) or worse catch the wires on fire
Posted on Jul 22, 2010
Testimonial: "thanks so what can i use to make this motor slower or faster"
  • Sean Wright
    Sean Wright Jul 22, 2010
    go to any shop that sells sewing machines and accessories and you can get a foot pedal that is made for that purpose.
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
May 04, 2017 | Cars & Trucks
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
the spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
Sep 09, 2014 | Heating & Cooling
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
I am not sure where to connect the white/nuetral wire at the connection points under the back motor cover of a 1hp,pool pump. I am wiring pump for 230V, and have four wires running to pump motor.does the...
None of the above. You hook your two line leads (the two hot 115 lines) to L1 and L2 and you hook up the ground to the green screw. Do NOT connect the neutral to the motor.
Jul 29, 2011 | Sta Rite Sta - Rite 1hp Dura - Glas...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Aircompressor 1hp. 106-174541.how to hook up wires for motor and pressor switch
Unless the wiring has been removed, the pressure switch to motor wiring should be ok. The input AC 115 volt line connection goes directly to the pressure switch. Be sure to connect the line ground connection (green or bare wire) directly to the pressure switch box (green screw). Hope this helps!
Jan 17, 2011 | Craftsman Garden
C/l pump 1hp. hook up is a 220 orage cover wire ment for 220 wired &coverted to 110 at breaker pannel with out door receptial gounded on end. pump pluged into it put plug breaker at plug in keeps...
A motor set up for 230VAC will run on 115VAC but will overheat and shut down over time. The motor nameplate should tell you what wires need to be reconnected and how in order to operate the motor on a 115VAC circuit. Once you change the wires your motor should go back to normal operation.
John
Oct 26, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Need to know how the wires go on a kobalt 230 volt air copressor
When looking at the switch it self, There will be 4 contacts. On the switch 2 will be labeled Line (Power in) and 2 will be labeled Motor (power out to motor) . Hook the black and white wires from the power cord to the line side (Either contact, it does not matter). Hook the 2 black and white wires from the motor to the contacts labeled Motor on the switch. The remaining 2 green wires (one from the motor and one from the cord) are to be grounded to the case on the switch.
Oct 01, 2009 | Coleman Powermate 60 Gallon Air Compressor
Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50 Logo
94 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
