Question about SMC Barricade 7004VWBR Wireless Router
My wireless connection keeps disconnecting and reconnecting on both my laptop and netbook. Both work when the ethernet cable is plugged in from the modem...don't have a new router, haven't moved it, no change to settings how can I correct this...have tried restarting it SMC 7004vwbr
  • SMC Master
  • 17,816 Answers
Wireless interference can cause this, it may also be the output has dropped on the wifi router. IF you have installed florescent lights or new LED lights or a host of other things, there may be new sources of electromagnetic interference. A neighbor may have installed a device on the same channel as you. Try changing the channel in the router wireless settings.
Posted on Feb 05, 2018
    Habit-Forming:
  • 31 Answers
Try this....
First, make sure your laptop is 'not' connected to the modem/router via an Ethernet cable and follow the steps:
1. Go to "Control Panel".
2. Next go to "Network and Internet" and then "Network and Sharing".
3. Now click on "Manage Wireless Networks".
4. On this screen, remove all wireless connections by "right clicking" on it and select "Remove network" from the drop down menu.
5. After doing this, close the oepn windows and reboot the computer.
6. Once the computer is fully reloaded, scan for the "Wi-Fi networks".
7. Click on the available network that you want to access and select "connect".
8. It takes a moment, but then you will be asked to give a password for your Wi-Fi connection. Type in the password and click the "connect" button.
It should now be connected.
NOTE: If this doesn't work, you may want to reset your modem/router, and then once it is fully loaded again, repeat the above steps.
If this doesn't work, test seeing if your laptop will connect via Ethernet. If so, then your WiFi card may be going. You can either look to replace it/have it replaced, or get an external (plugs in via USB) WiFi card.
kakee
  • 1269 Answers
SOURCE: modem light is red won't stay green.
Make sure to configure the router according to your ISP settings. I believe you have a DSL connection. That means you need to configure the router using PPPoE
Posted on Apr 26, 2009
alexgalapin
  • 148 Answers
SOURCE: I have used my SMC rouoter to connect to my
  • if you have reset the router it has to be reconfigured call your router support
  • check also if can connect to modem with internet if none call ISP
Posted on Aug 12, 2009
  • 25 Answers
SOURCE: router disconects from modem-Belkin router/Wildblue modem
hi,
try to chk out the firmware of the router. in most of the cases firmware are the major problem for the disconnection of the connection if the device has been purchased a while ago. visit ur belkin website and look for the firmware for your router model no.
if the device is new then try to decrease the mtu size and temporarily disable the firewall of the router
gud luck
thanx and regards
sukhiii
Posted on Aug 19, 2009
  • 107 Answers
SOURCE: WRT54G keeps disconnecting itself, requires
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Posted on Mar 05, 2010
  • 36 Answers
SOURCE: smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
Posted on Mar 11, 2010
How can i install a wireless router with just my netbook
Setting up the router using a wireless connection may work. You can wire your router to your netbook using an ethernet cable (ethernet cable looks like a phone cable but the connectors are bigger). Check your netbook first if you have an ethernet port.
Apr 04, 2011 | Belkin Computers & Internet
My wireless network connection status in connected speed is11.0 and my signal strength is good but I cannot connect to the internet
Are you running any Internet Security software such as Norton? Also make sure your wireless router is actually connected to the Internet, just because your laptop is connected to the router doesn't mean the router is connected to the internet.
If you can, plug your laptop in to the router via an ethernet cable to make sure Internet access is working, alternatively if you have another computer connected to the router check the internet access on that one.
Also try doing a soft reset on the router, just disconnect from the power for about 30 seconds, reconnect, wait one minute then try again.
Jun 26, 2010 | Computers & Internet
I want to connect to a wireless router with my laptopbut dont seem to the wireless drivers.i have tried to connectwith virgin media modem and router .followed all instructions and when i remove ethernet...
Sir, try downloading the wireless driver from your laptop company's website. Or form the drivers cd/dvd they provided you. Then you can connect to any wireless capable modem/router from your laptop.
The ethernet cable provides the internet pulses into your laptop. If you remove it, your internet connection gets disconnected.
Jun 30, 2010 | Advent Netbook
My wireless connection keeps disconnecting and then keep acquiring for network address but never connecting. My other laptop works well with my wireless router. I could reconnect to wireless by plugging in...
You may need to update your Wireless drivers:
Unlike the newer laptops, the T42 doesn't have it's own wireless switch. So in order to get the wireless working, you need to also make sure that the Power Management driver and the Hotkey driver are installed as well.
Load the drivers in this order:
1) Power Management driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4GXPEG
2) Hotkey driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-68000
3) Wireless Driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70504
After downloading it, you must go into C>Drivers>Win>Wlanint and run the setup file from there.
4) Access Connections (Optional) - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4ZLNJB
Nov 03, 2009 | IBM ThinkPad T42 Notebook
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
3 g dongle
the only way to connect this
is you will have connect your laptop to normal internet such as bt for a few mins /vear ethernet lead /
then down load mobile partner
install this to your laptop/
disconnect ethernet / plug usb 3 in /open mobile partner/ and this should see it then connect
Aug 28, 2009 | Acer Aspire One AOA150-1784 Netbook
Want all my computers to work online
yes because you need to set up the network on your pc and supply it with the passkey or try using it with ethernet cable
Jul 18, 2009 | D-Link AirPlus DI-524 Wireless Router
Why does this keep happening??? Please advise...
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Dec 04, 2008 | Linksys Wireless-G WRT54G Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
SMC Barricade 7004VWBR Wireless Router Logo
200 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
