Question about Microsoft Office Excel 2007
Need formula for Excel
I need a value of x if Sheet3! W2 = Clark College and Sheet3! X2 and Y2 are blank I thought the formula below would work but it isn't. Help!!!
=IF(AND(Sheet3!W2="Clark College",ISBLANK(Sheet3!X2:Y2)),"X"," ")
  • 2,005 Answers
Try using "count if blank"
I am assuming that you need the value to be on sheet 3
If you want the value to be on another sheet, it is more complicated, you will have to "paste special" the value to a different sheet.
Posted on Jul 22, 2010
Formula for cell that is not blank
You can use IF and ISBLANK. Put this formula on Sheet 1 D1:
=IF(ISBLANK(Sheet3!AM2),"x","")
You can replace "x" by any other value you need.
Mar 04, 2010 | Microsoft Excel for PC
What are the steps, when given two coordinates to work out the bearing and distance between them
Let us start by setting the terminology right: To locate a point on a plane you need two coordinates ( an X-value and a Y-value). If the point is in space, you need a third coordinate which may be called z, but let's us not complicate things unecessarily.
With just two coordinates, we will be able to locate at best one point.
Let us rephrase the problem: When given two sets of coordinates, how to calculate the distance between the two points.
Let (x1,y1) and (x2,y2) be the coordinates of two points in a plane. To calculate the distance between the points, one uses the formula
d (distance)= square root of ( (x2-x1)^2+(y2-y1)^2)
When you calculate the distance you must substitute actual coordinates for X1, Y1, X2 and Y2.
As regards the bearing, I am afraid that I am no expert in maritime nor in aircraft navigation and I will not venture stray out of my area of competence. However, I know that you need an axis that defines the direction with respect to which angles are measured.
If your reference axis is the horizontal axis on a cartesian plane you can determine the angle that the line joining the points makes with that horizontal axis by calculating its cosine, then extract the arcosine.
If (X2-X1) and (Y2-Y1) are both positive then cos(theta)=(X2-X1)/d, where d is the distance (positive value) calculated above.
Feb 27, 2010 | Casio FX-7400G Plus Calculator
Excel formulas
Below is the formula for "2". The logic should be obvious from this so you can adapt for "1" or a combination of 1 and 2. This need to be written as one long formula so I have pasted it in to this reply so you can do a copy and paste into your spreadsheet. Sorry its not very readable in this form but you could paste into word so you can break it down and examine structure.
=IF(OR((AND(Sheet3!A12="WA",OR(Sheet3!AH2="Lewis",Sheet3!AH2="Pacific",Sheet3!AH2="Wahkiakum"))),(AND(Sheet3!A12="OR",OR(Sheet3!AH2="Clackmas",Sheet3!AH2="Multnomah",Sheet3!AH2="Washington")))),"X"," ")
Aug 18, 2009 | Microsoft Office Excel 2007 Full Version...
Need an excel formula
This Boolean formula:
=(A2="Clark College")*(NOT(ISBLANK(B2))+(C2="Graduate"))
it will return values of 0, 1, or 2 depending upon how many of the conditions are met. This is for A AND (B OR C). [A*(B+C)]. If you mean (A AND B) OR C use the format (A*B)+C.
Aug 13, 2009 | Microsoft Excel 97 Full Version for PC
Need a formula in excel
use if statement
=IF(AND(OR(A1="clark",A1="skamania",A1="clickitat"),B1="WA"),1,0)
where A1=T2 and B1=U2
Jul 16, 2009 | Microsoft Office Excel 2007
Need an excel formula.
The crude solution is:
=IF(Sheet3!I2="WA",IF(Sheet3!H2="Vancouver","X",IF(Sheet3!H2="Camas","X",IF(Sheet3!H2="Ridgefield","X",IF(Sheet3!H2="Washougal","X",IF(Sheet3!H2="Stevenson","X",IF(Sheet3!H2="Hockinson","X","?City?")))))),"?State?")
Where ?City? appears when the city referenced in H2 is not part of the lookup
and ?State? appears when something other than WA appears in I2.
But there is probably a better way to do this using an array of valid values like the one below:
AL NY TX WA Birmingham Albany Abilene Camas Huntsville Buffalo Galvaston Hockinson Russell New York Houston Ridgefield Stevenson Vancouver Washougal
In the scenario you could stuff the array in another worksheet and use the HLookup function to find the "Sheet3!I2" value in the first row of this array to determine which column to look in, then VLookup "Sheet3!H2" in the column of that array to see if the city referenced exists. Of course this is a much more complex formula, but it would be easily extendible without changing the formula every time.
For mor info, see "Lookup and Reference Functions" in the Excel Help.
Jun 11, 2009 | Microsoft Excel for PC
Need formula for excel
Well the symbol for greater than would be => and for lesser than would be +<  so if you can incorporate that into your formula it should work. Something like A2=>Sheet3.
Formula not working correctly
You need to change the =IF(AND to =IF(OR
Using AND is saying both conditions must be true. Using OR is saying either condition 1 or 2 need to be true
Apr 16, 2009 | Oracle Database Enterprise Named User Plus
I need a formula based on the value of two cells
You were of to a good start. Try using the AND function in the IF Formula as follows:
=IF(AND(Sheet3!H2="Clark College",ISBLANK(Sheet3!I2)),"X"," ")
Apr 15, 2009 | Oracle Database Enterprise Named User Plus
Excel formula related to a date range
Use the IF and Date functions together. On sheet 3, put the birthday (3/15/1954) in cell B1, put the beginning date (1/1/1946) in cell C1 and the ending date (12/31/1964) in cell D1.
Then on Sheet 1, but the following formula in the cell you want an X to be placed in.
=IF(AND(Sheet3!B1>=Sheet3!C1,(Sheet3!B1<=Sheet3!D1)),"X"," ").
Make sure you type the formula Exactly as it appears.
Mar 20, 2009 | Oracle Database Enterprise Named User Plus
Microsoft Office Excel 2007 Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
