Question about Maytag MER5770 Electric Kitchen Range
The code F1 appears on the digital display. Cancel does not turn the oven off. Maytag model mer5770 range
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a Maytag MER5770 oven range. I accidentally activated the oven lock with the oven door in the open postion. I have an F9 code displayed. I hit the cancel button and then turned off oven at t
    I would imagine if you trick it into thinking th edoor is closed it will unlock for you. Look for the switch/button that does this and then try cancelling again
    Mar 12, 2012 | Maytag Kitchen Ranges
    MAYTAG GEMINI model MER6770AAW Fault code F1-L -same code for upper and lower. After reading other comments, it appears that the temp sensor(s) are bad. I need to find part #'s and cost. Thank you Pete
    Here's a late response, hopefully helpful to someone... I had the same issue with same model Maytag range. I pressed the CLEAN option on the touchpad (bottom oven) and that option seemed to work. I pressed Auto Set and I let it go through "remove oven racks" until the display panel read 100 degrees and then pressed CANCEL. About 30 seconds later, when the oven was out of "clean mode," I pressed BAKE, then Auto Set, and it's been working fine ever since...
    I'm sure the sensor needs replaced and will go permanently sooner or later, but if anyone out there gets the F1-L code but hopes to at least temporarily revive your oven maybe this will do the trick.
    Feb 15, 2010 | Maytag MER6772 Gemini Electric Kitchen...
    Maytag oven shuts off?
    Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
    This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
    Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
    Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
    1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
    4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
    7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
    Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
    The display at top of stove is showing "F1" and continuously beep
    Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
    or
    F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
    Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
    F1 alarm and oven won't turn off
    Turned off circuit breaker and serviceman coming. A piece of toast caught small fire inside oven, and I suspect the temp. rose too high and now oven won't turn off either when plugged on. Thanks anyway.
    Jan 19, 2009 | Maytag MER5770 Electric Kitchen Range
    Maytag Model # MES5770AAB F1 error
    Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
    Setauket mom
    Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
    Maytag MER5770AAW Oven
    f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
    Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
    F1-6 Fault Code
    This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
    Maytag Gemini fault codes.
    Fault code Suspect area Fault code Suspect area
    F0 - 0 None
    F1 - 1 Runaway cook upper oven
    F1 - 2 Runaway cook lower oven
    F1 - 3 Runaway clean upper oven
    F1 - 4 Runaway clean lower oven
    F1 - 5 Keypad cancel upper
    F1 - 6 Keypad cancel lower
    F1 - 7 Keypad disconnected
    F1 - 8 Keypad shorted
    F1 - 9 Slave
    Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
    Maytag MER5770 Electric Kitchen Range Logo
    127 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
