Question about Brady TLS 2200 Label Printer
I am getting an error on my brady tls 2200 "error head open"
Brady TLS2200. I turn it on and get a error CHKSUM
Once again, first thing in a GOOGLE search!
Brady TLS2200 manual
https://www.cableorganizer.com/images/brady/tls2200/manual.pdf
Page 77 error messages
Error in Checksum
The software was improperly installed on your printer. (or lost or corrupted in the memory.)
Contact Brady Technical support group.
Aug 03, 2016 | Brady TLS 2200 Label Printer
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
Looking for a part number for the internal battery
Hope this helps this should be the part# for battery pack for you label maker P# TLS2200-BP
Jun 10, 2014 | Brady TLS 2200 Label Printer
How to print out two lines
There are a good number of printing examples found in the PDF users manual (link below). This printer has a good many features, and printing modes.
Which type of label are you trying to print?
http://www.bradyid.com/bradyid/pleaseWaitView.do?url=http://www.bradyid.com/downloads/TLS2200_Manual.pdf&msgkey=downloadsDetail.pleaseWait.msg
Feb 28, 2011 | Brady TLS 2200 Label Printer
Error message: codesum: C47B72 memory error
Your printer firmware got corrupted or if yu tried to upgrade, it did not complete successfully. Most probably you will have to do a firmware install
Jan 06, 2010 | Brady TLS 2200 Label Printer
Tls pc link is asking me to set it to periphial mode but i dont know how to it does not have key or a screen, just on/off, functions and feed buttons..
Find the latest product updates, manuals, tutorials, printer drivers, product demos and much more for your Brady products in the below link:
Brady
Hope it helped.
Nov 22, 2009 | Brady TLS 2200 Label Printer
IT SAYS TO REDUCE TYPE SIZE AND I DONT KNOW HOW
To Reduce the TYPE Size Press the SHIFT KEY together with Down arrow to reduce Up to increase
Hope it helps
AZSUNS
Nov 25, 2008 | Brady TLS 2200 Label Printer
Errors
I believe this is a checksum error. Most likely the CMOS Button Cell Battery is dead and CMOS
memory is now corrupt !.
Replace the CMOS Battery if less then 3.6V. It is located under the Main Battery.
Then reload the latest software !
Hope this solves your problem
Regards
AZSUNS
Nov 09, 2008 | Brady TLS 2200 Label Printer
Brady tls2200 label printer
Go to setup mode
(Func + Setup Keys Together)
"Printer" is first line of text, Press Enter
Scroll down 4 times using Down Arrow
"Burn Temp" is selected, Press Enter
"Burn Temp is 0?" Using the Up/Down Arrow you can increase/decrease the burn Temperature. +2 or 3 should do the trick.
AZSUNS
Nov 01, 2008 | Brady TLS 2200 Label Printer
Brady TLS 2200 Label Printer Logo
107 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
