Question about Initial 23" LCD TV/DVD Player/PC Monitor Combo - DTV-232 DTV232
Having trouble getting the correct channel when hooking to a satelitte
    President:
  • 1,099 Answers
Access the main menu of your satellite by pressing Menu on your satellite remote.
Step 2
Click on System Setup.
Step 3
Arrow down, and click on Local Channels.
Step 4
Scan for local channels, like your local NBC, ABC, CBS, PBS and FOX affiliates, by pressing the Scan button. Wait for the scan to complete before you continue.
Step 5
Check your on-screen guide to see if your local channels properly display. Note: You will only receive information about the programs if you subscribe to local channels as part of your programming package. However, the channel name and number will still display in your on-screen guide if the scan was successful. If the scan was not successful, try adjusting your antenna to see if you can receive a better signal.
Also note that
Step 1
Press Guide on your satellite remote to see a listing of channels.
Step 2
Click on the channel you want to add, or type in the channel number if you know what it is.
Step 3
Use your remote to navigate the purchasing options for that channel. A pop-up will appear telling you to push OK if you want to subscribe to that channel. If you opt to subscribe to that channel, your satellite receiver will automatically add it to your programming package, and it will appear on your next satellite bill.
Hope you find this helpful, Good luck....
Posted on Jul 22, 2010
I can not record from the pc screen on tv to vhs i can the normal channels but not the pc screen why?
If you have "Cable or Satelitte" your VCR may be hooked to a secondary output from that box not the output of the TV, most TV's do not have an Audio and Video output. This would be one reason why you could not record a PC input
Feb 04, 2013 | Televison & Video
Having trouble with direct connection from VTM190A VHS to an old RCA TV- have red cable to red and yellow to yellow and both units reading channel 4, but still only static. Obviously don't have something...
Channel four on the television wouldn't be correct when hooking up with the yellow red and white RCA cable. The television should be on video/aux/input etc. You should see a button for you to do that on the tv, on the tvs remote control, or within the tvs menu.
Apr 22, 2011 | Hitachi VTM190A VHS VCR
I have a 2008 Dodge Ram with Sirous Satelitte built into the radio. It's locked up and will only show channel 184 and not play anything. I disconnected the battery and that did't correct anything. Any...
I have the exact same issue on my 08 Ram 1500. It even shows the same channel 184. Of course, it's warranty just expired at 39000 miles. I took it to the dealer anyway, and to quote the service tech "it points to the satellite module". Key word is points. A new module (the receiver) is $313 plus the $79 labor fee. WhenI asked if the new module did not fix the problem, if I would get a refund on the $313, he just kind of looked at me and eventually said no. I am looking for other solutions....
Oct 18, 2010 | Sirius Satellite Radio Receiver
Not able to get digital channels
A lot of "digital LCD TVs did not have a digital tuner. All you can do is channel up and down through the normal analog channels. You may still have to get a convertor box or subscribe to a cable or satelitte service.
Check the Find Manuals link below on fixya.com or if you can't find your model, you can also check www.retrevo.com for owners manuals and specs.
Jun 29, 2009 | Televison & Video
When connecting converter box, does the antenna hook to the in , and then another cable hook to the back of tv, I am having trouble.
thats correct , then you have to follow the set up procedures , AUTO SCAN for channels available.
May 03, 2009 | Televison & Video
I have the tv and i have the cable channels but they r fuzzy
Do you have a vcr/dvd player connected to this tv? Make sure it is off. Do you have a cable box? Make sure your TV is on channel 3 or 4 and the same for the cable/satelitte box. Make sure you have good grounds on your cables and rca jacks. Should be easy to correct this.
May 01, 2009 | Proview PA-32JK1A 32 in. LCD Television
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Go from the output of the satelite to the vcr/dvd input and from the dvd/vcr output to plasma set.
Mar 06, 2009 | Panasonic Televison & Video
I can't hook up the vcr
I would strongly suggest connecting a plain, coaxial cable wire from your sat box to the the ANT IN of the VCR. then use another coaxial to run from the ANT OUT of the VCR to the TV. Then you can change your TV to channel 3 or 4 as appropriate.
If you have a newer digital satellite receiver, this setup may not work. In that case, use two sets of red/white/yellow cables - 1 set will run from the out of the satellite receiver to the audio, video IN of the VCR. The second set will run from the audio and video OUT of the VCR to your TV. Then change your television to Aux 1, aux2 or whatever channel that corresponds to the red/white yellow.
Have fun!
-Tha Mp3 Doctor
Dec 31, 2008 | Emerson EWV603 VHS VCR
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Initial 23" LCD TV/DVD Player/PC Monitor Combo - DTV-232 DTV232 Logo
Top Initial Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
