Question about Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0
No GUI on startup.
After I installed windows Vista Ultimate on my laptop the GUI does not load on startup. I have to press ctl-alt-del to bring up the task manager and click on start new task and start explore.exe to get the GUI. How can I get the interface to start at startup?
    President:
  • 2,571 Answers
Try a repair installation.
Is this an illegal copy? If it is, it may have virus or malware problems.
Posted on Jul 22, 2010
How do i stop a task on asus laptop
If it runs Windows, use the same key sequence.
Aug 15, 2014 | ASUS Computers & Internet
Have a hp pavilion a705w that shut down one day and upon restart NTLDR is missing error came up and said hit alt clt del what do i do
Windows was writing to a file when the power went off. Now windows files are damaged. I'm assuming you have Windows XP on the machine. Do you have your Windows XP cd?
Mar 16, 2013 | HP Pavilion a705w PC Desktop
A disk read error occurred windows vista
Dear customer i think you window corrupt and create a bad sector in hard disk.so plz re install windows vista.
Note:- If you are interstate change windows vista to windows7, because windows7 is more relabel and fast surfing windows. So you change vista and install windows 7 on you Laptop/Desktop.
Sep 18, 2012 | Dell Studio 15 Laptop
Everex stepnote VA4103M laptop computer. error message when turning on computer. bootmgr is missing. press ctl alt del to restart. computer does not boot up.
Hi. Something might have happened to the boot manager of your computer. Here's the solution for this issue. You should have you Windows installation disk with you inorder to do this.
Boot off the Windows DVD and then click Next at the first prompt:
You should see a link in the lower left-hand side for "Repair your computer"
The installation process will attempt to find your installation directory. If there's more than one in the list, select the correct one and then use the Next button again.
Click the first link for "Startup Repair"
The installation process will repair the system, and then prompt for you to reboot.
Jun 18, 2010 | Everex StepNote VA4103M Notebook
Bootmgr is commpressed press ctr+alt+del to restart
Option #1:
Boot from your Windows Vista DVD and select Repair your Computer -> Startup Repair.
Option #2:
Boot from your Windows Vista DVD and select Repair your Computer -> Command Prompt, execute the following commands:
bootrec /fixboot
bootrec /fixmbr
Reboot.
Option #3:
At the prompt to select your OS installation, click the button that says ‘Load Drivers’. This should bring up a explorer-style drive browser.Then just right-click on the drive you tried to compress, and deselect ‘Compress this Drive’, which should still be ticked on. Hit apply, and apply to subfolders/files.
Reboot.
Option #4:
Boot from your Windows Vista DVD and select Repair your Computer -> Command Prompt, in the command prompt, execute the following commands by typing them and pressing enter for each line:
c:
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
Reboot.(If the 2nd line fail, go back to 1st line and replace C with the drive letter of where your windows is installed.)
Apr 27, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the computer I only get a black screen with the message "BOOTMGR missing Press CTL ALT DEL" of course when you press CTL ALT DEL it just brings you back to the black screen with the same...
1. Put the Windows installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Oct 17, 2009 | Lenovo 3000 G530 Notebook
Bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
Jul 12, 2009 | Microsoft Windows XP Media Center Edition...
Blue blank screen is my problem
Problem: An update being pushed out to EEE PC 701SD causing machine not to load to full GUI
Symptom: Machine will start to load into GUI but will get stuck after loading taskbar.
To fix:
Open the Terminal window by pressing Ctl-Alt-T.
Enter the command 'sudo apt-get remove asus-p901-system-update azurebt'
Press power button to turn off machine.
Turn machine back on, open the terminal window again with Ctl-Alt-T.
Enter the command 'sudo apt-get install asus-eeepc-core'
Restart the machine.
May 23, 2009 | ASUS Eee PC 701 Notebook
My windows vista hangs often;
Download process explorer
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx'
Extract the program, make a shortcut and copy the shortcut to
START MENU- PROGRAMS - STARTUP
Now every time you start the computer process explorer will start up and you can kill any processes you need
also you can disable programs from startup by
start -> run -> msconfig -> startup tab
Dec 08, 2008 | Microsoft Windows Vista Ultimate Edition
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0  Logo
116 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
