Question about Goldstar M1003R Air Conditioner
The "Dry" Setting does what?
What does the "dry" setting do or not do?
  • Goldstar Master
  • 8,220 Answers
Removes the humidity in the air.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 22, 2010
Testimonial: "Thanks for answering my simple question quickly and simply."
  • yvette_2181 Aug 26, 2010
    Thank you for is info, I always wondered what the dry option on the air conditioner meant thanks again
2 Suggested Answers
dabeckham
  • 22 Answers
SOURCE: what's the difference between dry and cool setting
Dry is a dehumidifier option. There is a heating element in the unit to heat the cold air back up. The cold evaporator coil causes the moisture in the air to condense on the coil (this is why the AC leaks water) and the air coming out of the vents will be cold. If you are not wanting to lower the temperature in the room but want to take out the moisture then use DRY. All ACs take the moisture out of the air when they are on COOL. So, COOL drys the air and makes it cold. DRY drys the air but warms it back up before sending it out the vents.
Posted on Jun 15, 2010
Whars the correct way of cleaning and drying my activewear?
Top wear or underwear are pretty much the same. Machine wash, cold water, high efficiency detergent on a setting for synthetics.
For underwear use fabric conditioner and air dry, with a tumble dry when almost dry, on a low heat, warm setting.
For outerwear dry on a hanger and spray twice with silicone water repellant spray allowing a couple of hours between sprays. Make particular attention to seams.
Nov 24, 2015 | Motorcycles
What is the best setting to use to dry clothes
Medium or low heat and put a few DRY,clean towels in there.
AUTO moisture sensors will do the rest.
The HIGH setting is not good for the dryer or your clothing.
Always put in a dry article to speed the process up.
Permanent press w/cool down is good.
If you use the HIGH setting,you better be **kid and waiting for the clothes to be dry!
Sorry.
Aug 26, 2013 | Dryers
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Dryer is not drying
well sounds like 2 different problems happening at the same time the automatic dry setting not shuting off is the switch and the not drying is the heating element going bad
Mar 19, 2012 | Dryers
My dryer is taking to long to dry clothes and the setting dial moves very slowly if at all.
Make sure the exhaust vent is free and clear. Lint build-up can cause it to take longer to dry clothes. Also, try putting the timer on another setting to see if it makes a difference. If you are using "Auto", try putting the setting on a manual time setting to see if that helps. You may have a bad timer or bad moisture sensors.
Feb 24, 2010 | Maytag Performa PAV2200
Clothes do not dry on automatic setting
Sounds like you have a problem with the timer switch, it will control both the auto and timed settings.
You may need to replace it, or live with the timed setting, it is cheaper.
Hope this helps
Oct 03, 2009 | Maytag Dryers
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
More dry/less dry setting on atlantis dryer
The more dry less dry settings are basically how much heat you want to use. This is the sensor drying. There is a moister sensor in the dryer that senses the moister on the clothing. When it senses no more moister it will shut off and tell you your clothes are done. The trick with this is that you want to make sure you don't mix your heavy clothing with your light stuff. A t-shirt will dry much faster then jeans and it will sense that the shirt is dry and shut off. I put mine on about the second or third line on the more dry setting and my clothes come out fine. If you are mixing your clothing just put it around the third line. It all really depends on what is being dried. If it's heavy set it for more, if it's socks and such set it lower. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Goldstar M1003R Air Conditioner Logo
252 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
