Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
Whats making the fan on my welder not work
Whats making the fan on my old Lincoln tombstone welder not work
    President:
  • Lincoln Master
  • 2,030 Answers
The fan motor has probably burnt out, i see this alot...make sure the connections are good....you can try putting 120v to it directly, if it doesnt run you need a new one...if it does then you need to check all your connections
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Jul 22, 2010
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Why cant i find any thing about fluoresent HOUSE lights on here
It could be because you posted this under electric fans instead of lighting. You need to twist the fluorescent tube 1/4 the way round to release it from the tombstone ends. If the fitting is old this can be hard to do and the tombstone ends can become brittle and break.
Dec 11, 2012 | Dryers
Will a Lincoln Magum 100sg spool gun work on a Lincoln mig welder sp130t
Hi:Lincoln Magnum 100SG were made for the lincoln 140 and 180. There is no spool gun control on the old SP130T.
Sep 10, 2011 | Welding Tools
I need to find parts for my welder lincoln the fan coolin is not working
Any welding supply house can either get you a fan, or direct you as to where to find one locally.
--W/D--
Feb 19, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Hi I have a Lincoln Handy Mig I am running 0.30 wire welding a roll cage on a race car the welder keeps overheating {light keeps coming on} wont weld just sputters keeps kicking the breaker {20 amp}...
check to see if the cooling fan is working. put a box fan behind the welder so it will blow threw the vents on the rear, or better yet remove the side cover and let the fan blow into the side of the welder.if this works replace the cooling can......GOOD LUCK
Jan 29, 2011 | Lincoln Welding Tools
How do you wire the old lincoln 225 ac welder
What are you wiring? Power Cord? Fan? Transformer? You should see a white wiring block in the lower right corner if you are looking from the back. On the two top post the black and white wires are attached. The green ground wire is attached to the case. On the two bottom poles the fan lines attach one on each side and the transformer wires that are coming up from the transformer are attached on the same poles as the fan wires.
Apr 27, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
Need the diagram for an old welder, ac/dc 125/225 need to find out how to hook the fan up
Usually the fan if it is, 112/225V. It simply connects across the Line, Phase to neutral, but AFTER the mains switch. So that it is "On" only after the Power has been switched on.
Feb 10, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Where do I find a replacement cooling fan for a lincoln 225 stick welder?
I took my old one to Grainger and they ordered a new one that is 230V. Total cost of motor and fan $27.00
Jan 30, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
287 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
