Question about Toshiba Satellite M35X-S149 Notebook
How to clean screen
What is the preferred product to use to clean screen?
    President:
  • 2,571 Answers
Google
Posted on Jul 22, 2010
How do i change the language on my hp MX308
HI,
Follow these steps to reset the language and region on the product.
  1. On the product control panel, touch Setup. The Setup menu displays.
  2. Preferences . The Preferences menu displays.
  3. From the Preferences menu, touch Set Country/Region . The Set Country/Region menu displays.
  4. From the Set Country/Region menu, touch and then slide your finger up or down on the display to scroll through the list of countries, and then touch the desired country/region. The Preferences menu displays again.
  5. From the Preferences menu, touch Set Language . The Set Language menu displays.
  6. From the Set Language menu, touch and then slide your finger up or down on the display to scroll through the list of languages, and then touch the desired language. The home screen displays in the new language.
Thanks,
HP Printer Support
Jul 14, 2014 | HP Photosmart C4280 Aio Printer
Tip
How do I clean my flat-screen monitor?
<p>You don't have to turn the monitor off before cleaning it, but this will help you see the smudges and smears. If your screen is merely dusty, you can wipe gently with a soft, cotton cloth or try a can of compressed air. But if your screen is downright grungy, you might have to resort to some tougher tactics.<br /> <p> <br /> <p>Though some people recommend using Windex, ethyl alcohol and ammonia-based cleaners can yellow your flat-screen or laptop monitor over time, so it is best to avoid such products. You can find an array of commercial products specifically designed to clean LCD screens, but you may prefer to just head to your kitchen and mix up your own solution. Plain old water can do the trick, or you can concoct a solution of vinegar and water or isopropyl alcohol and water.<br /> <p> <br /> <p>Always use a soft cotton cloth, rather than a rag or paper towel to wipe the screen. Some people recommend special electrostatic cloths, like those used to clean eyeglasses treated with anti-glare finish, or even dryer sheets. Apply the cleaning solution to your cloth rather than directly to the screen and wipe in one direction -- from the top of the screen to the bottom.<br /> <p> <br /> <p>One final word of warning, never touch or press on your LCD screen with your fingers as this can cause the pixels to burn out.<br />
on Nov 28, 2010 | Televison & Video
What kind of product should i use to clean my TV screen.
Good luck and do rate the solution plz
What do i use to clean the monitor screen?
Nov 28, 2010 | HP 2009M Monitor
How do you clean plasma screen
Turn off the plasma display before cleaning it. Doing this is not necessary, but it's preferred, especially if you're going to use a cleaning solution spray. Since Plasma TVs use more power than and generate more heat than LCD TVs, it is best to turn it off AND allow ample time for the unit to cool to the touch before attempting to clean the screen. Failure to do this may cause your cleaning solution to evaporate before it has had enough time to remove any dust, dirt, or contaminants on your screen.[1] Some sources suggest unplugging the TV. Use a soft, lint-free cloth to remove fingerprints and smudges. Avoid wood-based products (paper towels, toilet paper, tissues) because they can scratch the screen. If stubborn dirty spots persist, go to the next step. However, be advised that some manufacturers, such as Pioneer, recommend no liquid at all on the front of their plasmas, lest it seep into the plasma display.
If you must use a liquid, spray-- a minimal amount of--the cleaning solution on the soft cloth, not on the screen. If the moistened cloth is not cleaning sufficiently, you can spray additional SMALL amounts on the cloth. At no time do you want the cloth wet to the point where the solution drips or runs down the screen! See previous point for the reason why. Use either just distilled water or non-ammonia or alcohol-based window cleaner. Ammonia and alcohol are substances which will eventually cloud any plastic with microscopic "crazing," with the effect of hazing and dimming the displayed image. After wiping the screen gently, follow up with a dry cloth
Apr 03, 2010 | Hisense TA42P40M 42 in. Plasma Television
Which anti vires is best
The "best" (but not the least cost) is http://www.kaspersky.com -- it detects much more than some other products, but it can slow-down your computer. So, it's a good one to use _IF_ you think/know that you have a virus-infected system.
Otherwise, other _free_ products will work:
* Microsoft Security Essentials
* AVG Free Edition
* AVIRA Personal Edition
just fine.
Feb 28, 2010 | Computers & Internet
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Cleaning screen on my 1080i hd panasonic????
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Dell 964 all in one printer
During the photo printing wizard, in printing options window, choose the printing preferences button. Once you are there, choose the maintenience tab located on the top of the screen. Choose the clean print cartridges button. Hope it works!
May 21, 2008 | Dell Photo 964 All-In-One InkJet Printer
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Toshiba Satellite M35X-S149 Notebook Logo
13 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
