Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
My washer leaves a yellow line on my white clothes
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. The yellow line is usually a resul of iron particulate in the water the machine uses. There are a few thing you can try to clean the machine.
You will not find this one in any manual.
Put one cup of bleach and 1/4 th cup dishwashing powder straight into the tub and run an empty or "cleaning rags cycle" with HOT water. You can add the juice of a freshly squeezed lemon or use lemon concentrate also with that. You may initially have to do this for 2 to 3 cycles to get rid of the iron deposits. After that you should use one of the products below before returning to reugular wash cycles.
There are other producs out there that you should use per their directions once a month.
http://www.affresh.com/#/home
and http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx
Also make sure you using HE washing machine detergents vs regular washing machine detergent. Here is just one example:
http://www.purex.com/detergents/ultra-purex-he
Thanks for choosing FixYa.
Kelly
Posted on Jul 23, 2010
Testimonial: "Thank you so much!!! I will try this today!"
  • Kelly
    Kelly Jul 26, 2010
    Hi again.
    I am just doing a follow up. Did the solution we provided you reslove your yellow stripe on white clothing issue? We would love to hear your story of either success or failure and your input will let us know if this actually "worked" or "did not work" for you. Thanks again for choosing FixYa.
    Kelly
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Dryer is leaving marks on my clothes. At least I think it's the dryer. It could be the washer. It's just leaving little gray lines, about an inch to an inch and a half long, in various places on my...
The dryer is prone upon leaving marks on clothes. The felt band surrounding the drum has worn out. Replacing this felt band will keep your clothes streak free again
Apr 28, 2010 | Washing Machines
Washer leaves spots on clothes
wipe the inside of the washer with a clean white cloth and see if anything shows up, it may be an ink pin that was left in the wash or a leaking seal that is letting grease enter the washer tube from the washer tub bearings.
Oct 01, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine leaves greasy looking streaks on clothes
tub bearing water seal gone ,needs new bearings and seals.
Jun 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer is leaving grease all over my clothes
I have this problem on my front loading washer too, but only when washing white clothes. I have just read that perhaps the inlet hose is disintegrating from the hot water being too hot. The hose disintergration can cause black greasy stains on the clothes. I am going to check out the inlet hose when I get home. Hopefully this is the problem... I am sure a new inlet hose is a lot cheaper than a new transmission or new bearings. BTW, my washer in only 18 months old.
May 18, 2009 | Washing Machines
Clothes
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
check out for this link
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaves a white film on dark cloths.
is she using powdered soap? if so shes been using too much. shell need to clean out the washer. a bottle of white vinager in a hot water wash with no clothes will clean it out. tell her to cut back on the soap. the box will say use a whole scoop. but thats just to get you to buy more soap. you only need half of that
Nov 28, 2007 | Washing Machines
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
107 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
