Question about ASUS P4B266 Motherboard
HP Pavilion asus p4b266-la Flash gone wrong
Friends,
I tried to flash my motherboard this weekend ot get it to recognize my new 2.6 processor. in doing the asus bios it went well just as it said it should untill reboot. I was to drop back into the bios set up using the DEL to enter setup and update the new settings and then continue on to windows.. well the issue is that it wont recognize my keyboard(s) as i have tried 6 different one and then it fails and gives me a hardware error and fails to boot any futurer. so I can't enther set up. I can't reflash it back to my back up. I think I am in a world of problems. the only other thing i can think to do is to order if possible a new bios chip from either HP or Asus...
Any help?
  • Steve King
    Steve King Apr 22, 2008
    FYI asus support number has changed (812)282-2787 still option 3
Try resetting the bios! there is a pin on the motherboard that you remove , then re-install . then restart computer. check the instructions on your new mother board, also could be a bad
keyboard, change out keyboard, try usb keyboard!>>>good luck!
Posted on Apr 22, 2008
Hp pavilion a815n, ASUS PTGD1-LA motherboard. Specifications state can do processor upgrade intel pentium 4 3.6-3.8 ghz w/HT technology. I did computer doesn't support and shuts down. anything I c
Hi James,
Your best bet will be to visit the Asus website and click on the 'support' tab at the top of the screen. Select the link for 'drivers' and specify your motherboard model. It's possible that there will be a BIOS update for your Asus m/board.
If so, do a BIOS flash and check if your PC will then accept your new CPU. NB! Take care when flashing the BIOS. Make sure there are no power interruptions etc. while performing this procedure as this could corrupt your BIOS software and render your motherboard useless.
Feel free to message me should you need more details or further assistance.
Best wishes,
Graemevm
Jan 12, 2012 | HP Pavilion a815n (PS512AA) PC Desktop
Repairing motherboards
HELLO!!
WHAT EXACTLY THE PROBLEM IS ???
Mar 03, 2008 | ASUS P4B266 Motherboard
Hp p4b266-la motherboard
what is the problem? can you give us some details here so that we can assist you with your problem
Aug 01, 2011 | HP-COMPAQ - P4B266-LA Motherboard
My hard drive went bad and my asus p4b266-c motherboard is not recognizing the replacement drive. How do I update the motherboard so I can finish installing windows xp pro?
hello, after plugging the new hard disk, you will go to setup from the bios settings and choose ide settings, when you get to the master primary press enter so that the computer can detect the hard disk automatically, once this is done, save the settings and restart your pc
Dec 23, 2010 | ASUS P4B266-C (P4B266-C WA) Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Need to replace my Asus A8N-LA motherboard. fan controlers gone
If I were you, I would replace the motherboard with the same model as Hp use´s...
When you try to find another compatible board you will have some problems due to exclusive computer case..sometimes you need to adapt things...too bad...it´s better to repair with original board....
Sep 09, 2009 | ASUS A8N-E Motherboard
I tried to install a new motherboard but it didn't work
Your bios needed to be set with the correct memory speed on your old motherboard or it did not support the memory you added or it was in the wrong memory slot or size. The beeping was telling you it was a memory error. I need more info such as processor and memory speed and type to help. What is your old motherboard? It sound like Bios settings but I need to make sure the memory and processor will work with *********** board.
Jan 16, 2009 | ASUS P4B266-C (P4B266-C WA) Motherboard
Hey
Did you check the cable settings and the the jumpers? If all these are ok then try reinstalling the windows... Maybe yuor mother board does not support the comp, but i doubt it....
Mar 16, 2008 | ASUS P4B266 Motherboard
HP PAVILION 760n
tell me if there is something i need to know like: what were the things that you've doing with your computer before the problem happened?? are there any recent hardware/software changes?? tell also your OS- is it XP or Vista...
first, let's try to check if the problem is with the monitor or not,okey? try unplugging the monitor blue connector at the back of the tower.and make sure that your monitor is turned-on.If you can see a colored bars displayed.you monitor is okey.if not, try a known good monitor...if it woks the problem is with the old monitor.(resolved)
2 (if not)
Now, complelely turn off your computer and try reseating all the cables, and your hardware components such as memory,video card,IDE cable and so on. but before doing so, unplug the power cable and then push the power button to drain the power.after reseating everything, plug back the power cable and turn on computer.try listening to the tower,tell me if you can hear some beeps also.
if no video issue is still there, try putting a known good video card if you have any.if a known good video card works then the problem is with the old one..
if the problem is still there after everything that you've done try calling the manufacturer. this is lead to a motherboard problem but try to call them first.
Jan 17, 2008 | HP Pavilion 760n (P6320A) PC Desktop
Upgrade my computer procesor
Socket type: mPGA478 (P4).
P4 – 1.4-3.4 GHz
P4 EE 3.2-3.4 GHz
MOTHERBOARD MANUAL: http://www.elhvb.com/mboards/OEM/HP/manual/danube_manual.pdf
It shows you how to take off and put in the CPU.
This is a guide on how to install the CPU/with FAN.
http://www.pctechguide.com/tutorials/Pentium4_CPU.htm
Nov 11, 2007 | ASUS P4B266 Motherboard
ASUS P4B266 Motherboard Logo
444 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
