Question about Garden
How do you replace the line on this model - Garden
  • 2,272 Answers
Please mention the model number and exact brand of the product.Also which line you want to replaced.Please give exact detail.So your problem can be solved in much better way. Keep updated.Thanks.
Posted on Jul 22, 2010
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
Fuel line replacement location. lines were old broken off. i don't know the replacement location. Weedeater Model # BC2400
one line goes from tank to primer bulb one from primer bulb to carb and usually a return line from carb to tank
Jun 28, 2010 | Garden
When I make a copy there is a white line through the middle of the copy. It whites out the wording if it is in this location
Solid white lines are usually caused by something being stuck near the developer roller (ie a scrap of paper). This will cause the developer along with the toner to get scraped off in that area. No toner or developer means no image and therefore white lines. A technician is usually needed in this situation to replace the developer. Some models can be replaced by the user but without knowing your copiers model number it is hard to say. PS one other possibility exists if the white lines are a bit wavy rather than solid and straight. White wavy lines are caused by a transfer corona or transfer roller once again depends on your model.
May 20, 2010 | Office Equipment & Supplies
Fuel bulb is not bringing in fuel when pushed
The larger line connects to the primer and returns fuel to tank. The smaller line has the fuel filter connected to it in the tank and connects to the small fitting on the side of carb.
Sounds like your problem is in the carb. You need to look your model up in Sears Parts because some models require replacing the entire carb.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
Should I leave a small peice of fuel line in the gas tank ?
Hi and welcome to FixYa, I am Kelly.
Ok.. We need your help here. I understand your going to replace a fuel line. Depending on what make and model your doing the fuel line replacement on the procedures are different. Some connect to the tank outlet. Some connect to the fuel tank screen pick up
others connect to a fuel shut off valve. They all end at the carburetor.
If you do a like part replacement the only thing you have to be concerned with is that it does not leak after you install the new line. What is most important is that you make sure to clamp both connecting ends of the new line. Fuel lines rapidly get hard and will leak causing the possibility of a fire during use / personal injury. I have repaired numerous BURNED units that early in the mowing season the owner had replaced the fuel line and by July or August it caught fire because they did not install the clamps or the right clamp when they replaced the fuel line. It isn't a difficult task.
Thanks for using FixYa.
Kelly
(If you need more details I need a make and Model number to be of any further assistance to you.)
Mar 30, 2010 | Garden
My McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Oct 13, 2009 | Garden
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
