Question about Hayward SAND FILTER, PRO SERIES
I have bought a used pump and pool and I not sure hoe to hook up the filter it's a above ground pool with a hayward sand filter HELP
  • 640 Answers
Here is a link to the owners manual for these pool filters. It should show you exactly how to connect the filter. It has diagrams to guide you.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Posted on Aug 31, 2010
How do i use my vacuum that came with my pro series pool above ground
put vac head into pool with swivel side to head prime hose with water then hook to skimmer
Jul 24, 2012 | Hayward Pro Series 18" Above Ground Pool...
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Need to know which is inlet and which is outlet connections
Take a look at the owners manual for these pool filters below. They have a diagram that should help you figure out where to hook your connections up.
Jun 19, 2010 | Hayward Pro Series 21" Above Ground Pool...
Do laterals in a sand filter move in a circle
Try consulting the users manual for these pool filters. It has a diagram of the parts of the filter and how they work. It should help you out.
May 20, 2010 | Hayward Pro Series 18" Above Ground Pool...
After replacing the sand in a sw256t swimpro
Try the owners manual for these pool filters. It has some really useful troubleshooting guides that should help you get this figured out.
Apr 29, 2010 | Hayward Pro Series 18" Above Ground Pool...
SAND IN ABOVE GROUND POOL
First, the vacuum should easily pick up sand if the pump is working properly. The sand in pool may be coming through a cracked or broken lateral. If you changed the sand recently and did not prefill the tank with water, then this could be the reason. Plastic parts do fail eventually. Be sure that you perform the rinse cycle aftewr backwashing to settle the sand bed. Instructions on filter tank.
Aug 12, 2009 | Hayward Pro Series 18" Above Ground Pool...
Sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
424 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
