Cooling i have a gateway 420gr one of my fans isnt working how do i find out where to plug it in i want to protect from overheating
  • 552 Answers
You can take the access cover off and follow the wires from the fan to the point where it is plugged in.
You can check the other fan to see where it is plugged in, and the non working one should be plugged in the same kind of plugin.
The power supply has the same power source for both fans, so if one is not working, it may be burned out or stuck.
Posted on Apr 22, 2008
Both fridg and freezer not cooling down. Diconected damper wich was continualy trying to close heard Evap. fan trying to kick on surge surge surge
well u answered ur own question if the evap fan isnt running then the compressor is overheated check the fan and make sure that the fridge isnt froze up unplug it for a few hours and plug it back in and see if it will cool for a while
Jan 22, 2011 | GE Refrigerators
Can I hook my Mac Cinema HD Display 2005 model to my gateway 420GR? If so, what do I need in the way of an adapter?
Windows PC and graphics card that supports DVI ports with dual-link digital bandwidth and VESA DDC standard for plug-and-play setup. You can check the specification of the graphic card and see whether they support those. For the cable if they are not in the box of the display, you can check the following ones.
http://www.dviator.com/en/DVIator.html
http://www.gefen.com/kvm/dproduct.jsp?prod_id=1203
Jul 08, 2010 | Gateway 420GR PC Desktop
Gateway laptop shuts off even when plugged in
Well, I'm not exactly sure if it is the cooling fan (you would have to see if its working), but it definitely could be an overheating problem. Another problem could actually be the battery, even if you have it plugged in, the battery can still cause it to shut down. If your computer is able, I would try using it without the battery and see what happens. And I believe that the cooling fan will fit. Here is a good site to help you troubleshoot your problem
Feb 24, 2010 | Gateway MT3705 Notebook
Gateway 420gr the HL DT ST DVDRAM GSA 4120B reads and burn CDs /cannot read DVDs inc Restore DVD
It's time to spend $40 to buy a replacement CD/DVD-writer.
There's no way to "fix" your "half-gassed" DVD-drive.
A technician would charge at least $25 to _look_ at your computer.
Instead, "invest" the $25 in a replacement.
Jan 04, 2010 | Gateway 420GR PC Desktop
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Gateway 420gr sata driver in XP
If you downloaded all the drivers for you 420gr motherboard at the Gateway site then you should be all set.
You didn't say if your hard drive was operating correctly or not?
Mar 30, 2009 | Gateway 420GR PC Desktop
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Gateway Laptop overheated and stopped working.
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Jan 01, 2009 | Gateway Computers & Internet
Booting
Has the fan been replaced? If not then the laptop will power itself off to protect from overheating. The fan is like a switch in the loop. Like old Xmas lights. One not working then none will work.
Aug 30, 2008 | Gateway M305CRV Notebook
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
