Question about Amana ARGS7650SS Gas Kitchen Range
Heat element glows in oven section of gas range but fuel valve does not open
  • Amana Master
  • 2,005 Answers
Replace the oven gas valve
Posted on Jul 22, 2010
My galaxy range model 790.60012604. The oven do not heat up . The element is lite up but the oven burner do not flame up which leaves a gas smell.
You need a new igniter, it may glow, but is probably not drawing the exact amperage required to open the gas valve decisively... You should also check burner tube and orifice for spider webs or other obstructions... Kenmore Range Stove Oven Igniter 316489402
Jul 05, 2016 | Galaxy Kitchen Ranges
Oven does not heat but broiler does
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
My oven working but grill not working, please advice me
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 17, 2015 | Ovens
One burner doesn't heat
Surface burners
The infinite switch
Feb 10, 2015 | Dryers
Kenmore c970
Surface burners
The infinite switch
Sep 07, 2014 | Kenmore Stove / Oven / Range Bake Element...
Oven is not heating up
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Surface burners
The infinite switch
Feb 10, 2014 | Kenmore Ovens
Oven section will not light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Apr 14, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven will not turn on. the gas burners are working. i don't smell gas, however, the oven will not heat up. any suggestions? we've had this range for about 5 years, and this is the first problem we've had...
the gas oven is ignited by a small electric element that glows red at a pre-set current it opens the gas valve and ignites the gas 9/10 times its as simple as replacing the igniter. the other 1 is a gas valve or the themostat control or a board ...try the igniter first cheap "relatvily" easy and you can probably do it your self ( if you are so inclined) Good Luck turn off the gas turn off the electricity and work carefully
Oct 12, 2009 | DCS RGS-366 Professional Gas Kitchen Range
Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 22, 2009 | Kitchen Ranges
OVEN WILL NOT HEAT
replace the oven ignitor, its glowing, but not strong enough to open your valve, very common issue
Oct 25, 2008 | Tappan TGF320 Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
88 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
