Question about Sport & Outdoor - Others
I have a quicksilver throttle control box on my boat. Where can i find a diagram on how to re assemble it?
bigtor1976
  • 21 Answers
SOURCE: quicksilver throttle assembly
yes the switch could be bad. Is it on the throttle? Does it work on the engine? I have had my switch go out twice on my mercury.
Posted on Dec 01, 2008
  • 52518 Answers
SOURCE: How to change a marine throttle cable
sorry never heard of this one
Posted on Apr 25, 2010
  • 5 Answers
SOURCE: diagram of throttle body assembly
Here is a diagram.
Posted on Jun 09, 2010
SOURCE: i have a quicksilver throttle control side mount
from what i have learned... (i have the same problem), is that it will beep for 2 reasons that i know of, water or oil. check your waterflow out of the motor, it should be ripping right out with good force. If not, your looking at a cooling problem. Check the impeller, its located in the lower unit of the motor, have you run the engine out of water? or even tuned the engine over quite a bit out of water? if so replace the impeller asap! If its not the cooling its an oil problem. In a lot of cases its an oil sensor, if so replace it fairly cheaply, or it could be that the injection system isnt working properly... this is an expensive fix the engine has to be completely broken down, what i did was just syphon the oil out of the reservoir, and mixed the oil into the fuel! If it comes down to it just mix it 50:1. that way you dont ruin your engine, as far as the beeping, it wont stop it unless its that stupid sensor, i guess just unplug it?
Posted on Jun 20, 2011
goldbill
  • 184 Answers
SOURCE: i hanve a warning buzz in my quicksilver motor control in my boat
Many of those gave a short buzz to tell you they were working. It's when your running and they buzz you need to shut down immediatly and find out what is wrong (engine heat, no oil ??_)
Posted on Nov 29, 2012
Where can I see quicksilver 3000 shifter/throttle diagram
try putting what your looking for in google and then click images.
Aug 19, 2016 | Cars & Trucks
How to take quicksilver 3000 siries throttle apart . Its a Murcury throttle handle.
from the picture I would remove all the screwI can find or see.first a mechanic's mirrow on a stick might shed some light on the problem also.there could be a clip on it also .
May 13, 2014 | Boating
Replacing shift cable, disassemble of control unit, Quicksilver 3000 control
Un Bolt controler From Side Of Boat
Remove Lower Panel 2 Screws
Undo 8 mm Nut Securing Front Of Cable Remove Cable .
Fit New Cable Re Attach Front Of Cable Slide Cable Back Into Controller Re Fit Lower Cover Re Attach To Boat
Good Luck
Mar 17, 2013 | Cars & Trucks
I hanve a warning buzz in my quicksilver motor control in my boat
Nov 17, 2012 | Quicksilver Boating
Just bought boat & prop will not in gage all the time
put your motor on the garden hose after you remove the propeller (you don't want to step into a spinning blade). remove the cover and start the motor.
Have some one shift the motor (without engaging the throttle).. This will show you which cable is the shift cable.Disconnect the shifter, and while it's running, shift it full forward and full reverse to fin the halfway point. Next return the control box to neutral and adjust the connector. Start it up and see if the control box will shift the gear box as far as you did by hand. If not you need to take the control box apart and move the cable anchor so you get more movement. Get a repair book and take pictures as the guts of a control box can be VERY confusing.
Sep 06, 2012 | Quicksilver Mercury/Quicksilver Parts...
I have a 1980s Flatacraft Force 4 with a Quicksilver engin control unit. The aim is to keepall as was. My problem is that the steering and Quicksilver units were both patialy dismantled some 5 years ago by...
That control box is very complicated and you should find some old merc mechanic to do that. The steering is very basic and will either have a wire wound cable that spools on to the steering hub, or a flat rack and pinion style which can go together either top or bottom. So try it out and reverse it if it steers backward.
Aug 21, 2011 | Quicksilver Mercury/Quicksilver Parts...
Quicksilver throttle
I recently aquired a 1982 Merc Bigfoot 60hp with a quicksilver throttle control. I am trying to find a manual as to the throttle operation. Any suggestions?
Chuck flochu1@yahoo.com
Jul 27, 2010 | Boating
Need to find rebuild kit for quicksilver throttle unit
here is a link to a mercury dealer with parts diagrams and part numbers. click here
Sep 23, 2009 | Bass Pro Boating
Quicksilver throttle assembly
Aug 25, 2008 | Boating
Sport & Outdoor - Others Logo
611 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
