Question about DigitalMedia MAXX Digital Media MXLC15DVD TV
I can't change modes for tv/av/svideao modes. It
Maxx Digital MXLCI5 - I can't change modes for tv/av/svidea/pc modes. It is stuck on pc
  • 10,594 Answers
Plug VGA cable at rear of tv and hook it with computer, make sure computer display resolution is set on low rate like 600x800 etc, once it gets signal from computer and turns On, change its input source to tv or av quickly.
Remove VGA cable from tv and use it as normal tv.
Hope this info will help you.
Thanks.
Posted on Jul 22, 2010
I HAVE A PANASONIC PLASMA TV,SERIAL NO IS TH-37PG9U,THAT STUCK ON HOTEL MODE,IT HAVE PC,DVD,AND NORMAL CABLE INPUTS,BUT NOTHING WORKS,HOW CAN I RESET IT TO WORK,THANKS IN ADVANCE
Be careful with this !
One wrong mis-setting and you could cause problems with your set.
On the TV itself, find the manual buttons down the side and select
-/V button press down and keep it pressed down meanwhile, on your remote...
Press the AV or TV/AV button three times in quick succession.
(depends which remote you have).
First press -/V then while still pressed down, press remote AV button 3 times
The menu will appear and you can change the settings.....just don't play around with it, it will go wrong very quick. Just stick to the objective and you'll be fine.
Oct 17, 2016 | Panasonic Televison & Video
How to change pc mode of sharp into tv mode
Use the input selector to change back to TV. Usually the first input on the list.
Jun 26, 2014 | Sharp LC-32SB24U 32 in. LCD TV
AV-R730 stuck in headphone mode?
Try a quick blast of compressed air into the headphone jack area. Worked great for me.
Apr 14, 2013 | Samsung Av-r730 A/v Surround Receiver...
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
I have a Gold Star TV, several years old, that is stuck on a black screen with AV on it. I pushed the wrong numbers to change the channel and cannot get it to f\go back to tv mode. Can you help me?
If you have the remote, press the AV/TV button. If you have no button with AV/TV written next to it, look for a symbol that is the outline of a TV with a small + sign in the corner. Or, worse case simply press each button one by one, until you find the one that switches the channel. If you bring up something on screen you're not sure about, turn the TV off and back on again.
Jun 09, 2011 | Televison & Video
While watching tv I touch something on the remote to make the tv go into "on timer" The red light is blinking. I have removed power then on again the remote and tv controls work but after 4...
Check the remote carefully for a stuck button. You may have pressed a button and it went a bit crooked getting stuck.
Also, remove the batteries of the remote and try operating the TV manually. If the remote is the cause, the TV will work correctly once you remove the batteries.
Another way to check is by using a digital camera, like the one in a cell phone. Turn on the camera and point it at the remote. If you see a white light coming from the transmitter, the remote is sending a signal. Look for a stuck button.
Jan 04, 2011 | JVC AV-27920 27" TV
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
What camera setting is required to show photos on TV. I have the video cable connected.
Set camera in playback mode, connect AV cord in camera and hook it to AV-in of TV and select that AV input with TV remote to view camera picture in TV as its being shown in camera LCD.
Sep 19, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Screen is dark
AV/TV Button
Press ¡° AV/TV¡± button,the will be some word show on the right top
of the screen, press ¡° PROG+/-¡± to select the AV source, and then
press ¡° VOL+/-¡±to enter AV mode.
TV
PC
SCART
http://www.denver-electronics.com/UploadetFiles/154/25/DFT-1504_Black_English.pdf
The Tv is starting or going into PC mode Or scart mode set to TV mode. Hope this helps Please rate me. The link is to all of the setting for the TV. Blue light is pc led.
Dec 21, 2008 | Hisense LCD1504 15 in. Television
Camera features canon 18-55 digital cmera EOS 350 D
It does different things depending on the camera settings and only works in the creative zone settings not the automatic settings.
In AV mode it changes the aperture
In Tv Mode it changes the shutter speed
In M mode it changes the shutter speed unless the AV button is pressed when it then changes the aperture
Apr 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
DigitalMedia MAXX Digital Media MXLC15DVD TV Logo
66 people viewed this question
Top DigitalMedia Televison & Video Experts
Marvin
Marvin
Are you a DigitalMedia Televison and Video Expert? Answer questions, earn points and help others
