Question about Jenn-Air Kitchen Ranges
For the range SEV47600B the singnal F7 comes on all the time withasound-arlarm
    President:
  • 1,099 Answers
Error F7 on your kitchen oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).
f-7 mean stuck button on key pad or stuck relay on oven control. if the problem started while oven was in use replace oven control board. if problem started while oven was not in use replace key pad . because control board shorts when oven is running then this error comes up. but if the error is both f7 e6 then, F7 E6 shows that Function pad button stuck or Bad clock try to Un-stick Button or replace Clock also if persist then check the connections to the control panel
-------- for any other codes :--- Code Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Un-stick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring . ------ for getting required parts you can get it from ---- www.repairclinic.com or from www.partselect.com --------- if not familiar with replacing part a local repair technician familiar with your brand /model is advisable as its normal problem and gets solved after replacing the required part .and yes its worth getting repaired. -----
This will help.
Thanks....
Posted on Jul 22, 2010
Git a yamaha xvs1100 2001 reffiting battery but alarm keeps going off when connect leads
Remove the alarm connections from the battery terminals and fit the battery,,,
Then fit the arlarm wires starting with the black,,negative wire first ....try this first ,,,
If it doesn't solve the problem
Remove the arlarm wires and reconnect them as before ,,,this time pressing the alarm deactivate button on your key fob ....
Oct 19, 2014 | Motorcycles
On my ge profile xl44 the f7 comes on this is a gas/propane range then the hi low flashes on
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Here is the part to order.
Nov 21, 2012 | Kitchen Ranges
F7 comes on when the oven is turned on?
Hi kev4uva,
The error code F7 shows that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | Magic Chef 31000 Gas Kitchen Range
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
GE oven JS900
I figure you me f7 and f8 here is what the coad means. there is no d8 code.
F7 This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced. F8 This code usually means that the electronic control needs to be replaced.
Good Luck and Please Rate FixYa!
Dec 19, 2008 | Magic Chef CGS3760 Gas Kitchen Range
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
F7 code flashes and beeps
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Dec 10, 2007 | GE Profile JDP47 Electric Kitchen Range
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
