Question about Orion HCCA 225G4 Car Audio Amplifier
Orion 250G4 was needing to know what terminals bridge this amp?
  • sant001 Mar 17, 2009
    i bridged my amp the way that it was described but it didnt seem to make a difference and im only running one '12' sub...
  • Scott Yowell
    Scott Yowell May 27, 2013
    left negative and right positive. bridged! that is left side - and right side +. to the speakers respectavly
    Scholar:
  • 61 Answers
Generally to bridge an amplifier you need to insert the positive wire from the sub to the positive wire on the first channel. And then insert the negative wire from the sub to the second channels's negative terminal.
Posted on Apr 24, 2008
How to bridge a Orion 250 hcca amp?
Should have a diagram on the bottom of amp or where you hook up the speakers to amp......Its usually the two outside speaker connections.....just be sure to hookup negative to negative and positive to positive.let me know if this helps.........
Mar 25, 2012 | Orion Car Audio & Video
How do i connect them to a one ohm stable amp
I take it that you have two woofers to connect. That said, you need to bridge your speakers to your amplifier to get them to really thump. Firstly, check on you amplifier where the bridging connections are, ie. you will have connecting screws for two speakers +-, and +-. There should be a mark indicating the bridged output, normally the first + and the last -. Now, connect the + of your one speaker to the - on the other speaker. The two un used terminals will go to the amp ie. the one - onthe one speaker and the + on the other one.
May 14, 2010 | Orion HCCA 10.2 Car Subwoofer
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Wiring h2 2ohm sub
ASSUMING YOU HAVE AN AMP FOR THIS SUB, CONNECT LEFT AND RIGHT JACKS, RED AND WHITE TO BACK OF STEREO RUN TO AMP AND THEN FOR A TWO CHANNEL AMP YOU JUST BRIDGE THE TERMINALS SO LEFT + ON CHANNEL ONE AND RIGHT - CHANNEL TWO
May 03, 2009 | Orion H2 15.2 Car Subwoofer
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
On lucent amps you sometimes have to bridge two terminals together to make it work. i need to know what two need to be bridged.
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
Jun 02, 2008 | Audio Players & Recorders
Orion HCCA 225G4 Car Audio Amplifier Logo
225 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
