Question about LG 50PC3D 50 in. Plasma Television
I have a LG 50PC3D television and the universal remote from the cable company is no longer turning on the TV or adjusting the volume......what can I do?
  • dtollice Jul 22, 2010
    I have a LG 50PC3D television that is 3 years old. The remote which is supplied by the cable company will not turn on or off the TV or adjust the volume. The remote is new and I try'd all six codes listed for LG. What can I do?
    President:
  • 1,099 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote.
That's it, I hope you got it going again............
Posted on Jul 22, 2010
  • 11,896 Answers
The batteries may have died or you may need to re-program the remote codes to use it again. What make and model remote is it?
    The remote is new from Verizon and the 6 codes to program the remote do not work. I have been told the problem is with the TV sensor. If that is correct.,...is the sensor easy to get to and easy to replace?
  • Nate Stansfield
    Nate Stansfield Jul 22, 2010
    It would be the remote or tv infared port. You will have to remove the rear of the tv, then pull out the circuit board so you can gain access to the front. Then solder off the old piece and on the new piece.
I need the entire board for LG 50PC3D
Try to Google the model number with "parts" to locate which boards are available via the internet.
May 23, 2012 | LG 50PC3D 50 in. Plasma Television
My L.G 50pc3d won't turn on and all I hear is
try to check all capacitors inside if looks like bulged on top try to replace it with the same value.
Apr 27, 2012 | LG Televison & Video
What are capacitors
Power packs,small '2 long cylinder,have lable like 10uf so on.Not worth replacing, not know the function of capacitors,replaced the whole board.
Dec 06, 2009 | LG 50PC3D 50 in. Plasma Television
Problems with LG 50PC3D 50 in. Plasma Television
are u using cable card? this unit has major problems when using a cable card.
Sep 10, 2009 | LG 50PC3D 50 in. Plasma Television
LG 50PC3D w/no picture
Your mainboard is damaged, replace it and that will solve your issue.
Jun 05, 2009 | LG 50PC3D 50 in. Plasma Television
Tv not turning on with renote control
are you using cable card? unit has major issues when using card
Dec 12, 2008 | LG 50PC3D 50 in. Plasma Television
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PC3D 50 in. Plasma Television Logo
Computer Repairing
Computer Repairing
