Question about Yamaha HTR-6130 Receiver
I hit the power button and it makes a click noise and does not turn on
  • johnnydj1999 Jul 22, 2010
    I put the fuse back in because it is not blown. Then tried turning it on. Is what i meant to say. Can the main power supply box go bad without the fuse?
  • 10,594 Answers
If receiver goes back to standby itself then it got some problem in amplifier output section and goes to standby due to activation of protection system.
Amplifier output section need to be checked for shorted out components.
If receiver does not go to standby but wont power up that means some problem with main power supply section and fuses on main power supply need to be checked.
Local tech will help you to fix the receiver if you have no experience of electronics stuff repair.
Thanks.
Posted on Jul 22, 2010
  • 1 more comment
    I took the fuse out and tried to turn it on also and it did the same thing. makes a click noise no lights nothing comes on. the only time it will try to turn on is after i unplug it from the wall and the above happens again (click noise and nothing)
  • Shahid Electronics
    Shahid Electronics Jul 22, 2010
    Fuse should not be took out from power supply, just check them and replace blown fuse with good one so main power supply may provide voltage to other circuits in receiver to turn it On.
    If fuse blow off again that means some thing got shorted out in that section and need to be checked with help of related schematics and multimeter.
    If fuse took out from power supply that means it is now disconnected/ isolated from other circuits of unit that are suppose to get power from power supply. If fuse are OK but receiver still does not power up then regulator chip in sub power supply section might be defective and causing that symptoms.
    Schematics are needed to check voltage supplies in receiver to find out what is missing that is preventing receiver to turns ON.
    Thanks.
I replaced the power supply unit on my 50" ProScan flat screen and now it wont even turn on just a clicking sound when you hit the power button.
The replacement power supply could have been installed incorrectly or may have been defective as received.
Nov 20, 2014 | Proscan Televison & Video
83 honda magna wont start makes clicking noise when i hit the start button
Try to jump the starter by running a jumper (posative voltage) wire to the starter...
Mar 25, 2013 | Honda Motorcycles
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I hit power button then start start light flashes and wont start
If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
Oct 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Will not turn on
start up circuitry needs trouble shooting probably one of the regulators or flyback.
Mar 13, 2008 | RCA P46921 46" Rear Projection Television
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Yamaha HTR-6130 Receiver Logo
80 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
