Question about KitchenAid KHMS155L Microwave Oven
No power to the microwave
Hello Julianfix - you provided the info. below in suggestion to the problem I'm having with my microwave due to my husband slamming to the door. I have another question.....does the microwave need to be un-installed to check this, or can this be done while it's still mounted over the stove? Also, is there someplace that we can go that will show us how to open the microwave to check the switches inside?
Thanks so much for all your help!
check the micro switches where the door latches , you have to open the microwave to check inside if switches are in their place or broken
  • 975 Answers
First , it need to be taken out wheres mounted , your gonna need someone whos handy and have the requirements tools , its an easy process to check . TOOLS NEEDED ? a screwdriver and a multimeter to check continuity and also to check the switches . just place the microwave on a table , theres about 4 up 8 screws on the back to remove that metal cover, and check inside , door latch switches & interlock switch. good luck. hope it helps
Posted on Apr 22, 2008
Hello, I'm looking manual for a microwave. Thanks.
Very difficult to help get you a manual when you provide no make / model info ...
Feb 12, 2015 | Microwave Ovens
How do I re-code our Galuxy Microwave?
I not know if this matches you unit, but it may help give some guidance on getting your keypad working again. Next time, please provide manufacturer and model number, which will help solve your problems faster. https://www.youtube.com/watch?v=_yWSU0kTkTg
Feb 10, 2015 | Microwave Ovens
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
Digital panel will not come on. Nothing works! I wanted to use the timer but hit the
Hello, welcome to Fixya!
Your unit is either having a power problem or a display problem. But it is most likely a display fault.
Click the below link and let us fix it together.
For detailed info, click here: http://www.fixya.com/marketplace/servicepage.aspx?srvid=15749
Good luck.
Nov 19, 2011 | Maytag MMV5000 Microwave Oven
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the...
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
Sep 20, 2011 | Kenmore 63652 Microwave Oven
Our lg microwave Model LMVa925SB seems to cut out when starting it all the time and we have to reset our outside power switch. My husband changed the switches as told by a home depot person to another...
You may have an "Earth Leak". That can be caused by, in microwave ovens, spilliage on the turntable motor causing a "leak of mains power" to Earth and tripping the RCD switch.
Have a look at the motor from underneath where the inspection cover can be removed.
Or
a leak from within the appliance itself due to leakage of boiled over/steamed food. It is clearly not safe to use as it is.
Dec 22, 2010 | LG Microwave Ovens
Gow do register online?
Find out the manufacturer or brand, model and serial number of the microwave. Google the brand name and then navigate to the manufacturer's web site. Look for something like "register product", "customer care" or "owners" and click on it. You should be prompted to supply your name, address, date of purchase, model, serial number and probably even more. Generally, you'll only have to divulge the info listed above to register - but some sites may be a little pushy for info like household income, etc. If you'd rather not supply that - skip it. If you aren't able to submit due to the site balking at missing info - then you'll have to fill out the registration card that came with the microwave (but only put down the info you're willing to provide) and mail it in. Done.
Please rate this reply - thanks!
Dec 15, 2010 | Microwave Ovens
I have lost the manual, where can I get a new one please
Hello :
Check this link for manual please :
R-654 800 Watts Convection Microwave Oven manual .
It could be that the link I've provided empty . If so , please look for the manual there , i found it , but due some techincal issus the link could come to you empty [not useful ] .
good luck .
rate please !
Mar 21, 2010 | Sharp R-654 Convection/Microwave Oven
Microwave has no power.
Since you have power going into the cord, there are three things to check next, with reference numbers from the exploded view found via the link below: REF # 1626 internal fuse REF # 1430 magnetorn thermostat REF # 1121 flame sensor If any of these parts is open, you will have a "no power" / "dead" condition. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 11, 2007 | GE JVM1660 Microwave Oven
KitchenAid KHMS155L Microwave Oven Logo
62 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
