Question about Craftsman 25cc Gas Line Trimmer
Where can i get a primer bulb for my craftsman weedwacker
    Problem Solver:
  • 6 Answers
Sears
Posted on Jul 27, 2010
5 Suggested Answers
  • 4 Answers
SOURCE: dont know how
most of them are a complete unit and you snap it out of the housing then unhook the hoses make sure to keep the labeled because the fuel will only go you way.
Posted on Aug 19, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
SOURCE: Problem with primer bulb
Reverse the line connections at the primer bulb. Look carefully, the long port has the line going to the tank, the short port on the bulb will connect with the fuel line to the carb.
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Posted on Feb 25, 2010
Testimonial: "Yes, was almost exactly what I needed. Did have to search to find which port on the carburetor was the inlet an the other the outlet."
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
My craftsman weedwacker 27cc curved shaft wont start and cant figure it out
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
Nov 24, 2014 | Craftsman 27cc 2Cycle Full Crank Curved...
Fuel want pull into bulb on my craftsman 27cc weedwacker #711200
There are 2 fuel lines going into the back of the primer bulb. One line goes from the back of the bulb into the fuel tank, and the other goes from the back of the bulb into the carburetor. I believe that the line that goes into the fuel tank has disconnected from the back of the bulb. You will need to remove the bulb, find the line that dropped off of the bulb and into the tank, and reconnect the line to the back of the bulb.
Jul 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman weedwacker model #358797150 will not pick up fuel
Have you checked the fuel filter and made sure it is not plugged. Make sure the primer bulb is not cracked or leaking pressure. If you have then I would be sure the fuel cap is not bad. To check the cap you should be able to put the cap on the tank pump the primer button to build pressure in the tank and then turn the cap a turn or so and hear the pressure release. If that is all ok then I would think the diaphragm in the carb is bad and the carb needs to be rebuilt.
May 22, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
Missing T piece from primer bulb to carburator
Sears has replacement parts and so do the OSH stores. If there's no store close, check with a local lawnmower shop and I'm sure they've got lots of replacement parts.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Sep 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
565 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
