Question about Microsoft Xbox 360 Console
Red light problem
How do you fix a red light e 73 problem
  • 206 Answers
You have to get it reflowed or you can put a thermal paste on it to fix it
i hope that i could help!!
Posted on Jul 22, 2010
  • resindrip Sep 09, 2010
    I had the same problem with my 360 I found that if you unplug your ethernet cable every time you turn your 360 on and off it works. Now if your 360 doesn't start try unpluging everything for about 45 min to an hour. If it works then all you do unplug the ethernet cable and you will be in luck. I had my 360 on for 24 hrs and no problems yet. Hope it works for ya! Good luck
I have a 0900-73 and found this site which has a PDF for it. I believe it covers other versions also.
http://www.powerline.com/#!200-watt-dcac-inverter/c1ri9
Jan 14, 2014 | Powerline 0900-73 Slimline Inverter
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
The main power buttton has one red line instead of lighting up green. ALSO IT SAYS ON TV CONSOLE SYSTEM ERROR E 73
sorry bud. youve got the "red ring" basically your xbox needs to be taken apart and or get a new one. this happend to me and to fix it was expensive as ****. it doesnt happen alot but when it does..it sucks. no way of fixing it yourself. sorry dude.
Dec 08, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
I have one red light on my xbox 360 elite with code E 73
https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
hope this helps its two ebooks on how to repair red light error ,full instution plus pics show u how.this download is only there for 7 days or 100 downloads.DT
Feb 23, 2010 | Microsoft Xbox 360 Elite Console - Black
3 red flashing lights on xbox360
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Feb 07, 2010 | Microsoft Premium System for Xbox 360
E 73
The E73 error is caused by the scaler chip at the back of the console taking too much heat. To fix it you need to stop the heat build up.
You can do this yourself using a good guide that will show you how to fix it with household items or you can send it in and they will fix it for you.
Jan 17, 2010 | Microsoft Xbox 360 Console
I have an one red light problem and error 73. Don't use ethernet
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm This should help you, I repaire these all the time and as soon as you get rid of those x-clamos and use the screw and washer set it fixes this problem. My name is Tim Ehrhart and I hope this helps you
Mar 15, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
I have 1 red light flash on xbox 360
Hi, 1 red blinking light is an indication of an electronic failure. The E 73 is the failure code. If this unit is under warranty, call Microsoft and they will issue a return label for the repair. Good Luck to you!
Feb 22, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
158 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
