Question about Kenmore 44423 Side by Side Refrigerator
Ice maker is not working (for kenmor 106-4442-603)
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
The ice maker has stopped working, the motor is co...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working, but water is still working
heatman101
dhghdg
Dec 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
heatman101
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator ice maker stopped working
heatman101
mnnmbnm
Kenmore 44423 Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
