Question about HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner
Recent Dvd player was connected to computer. However computer does not recognise it
I have hooked up a dvd burner to my computer. When I click "My Computer" the Dvd burner does not show up. Any help would be appreciated.
I looked at this link http://geeksquad.fixya.com/support/r380953-missing_dvd_cd_rom_drive_letter
Would this be the answer to my problems?
  • VampyreJoe Sep 30, 2008
    Works some of the time and doesn't the rest. This is becoming a real problem and i no longer have the install disk??
BETTER YOU INFORM TO YOUR COMPUTER SOFTWARE INSTALLER BECAUSE SOME TIME DVD WRITER INSERTED BUT PLUG NOT CONNECTED TO DEVICE SO YOU CHECK IT OK DONT WORRY
Posted on Jan 28, 2010
RIGHT Click My Computer - select Properties - select Device Manager - then RIGHT Click the DVD drive - scan for hardware changes. I had the same issue and this is what fixed it.
Posted on Nov 25, 2008
  • 8,596 Answers
Make sure the power cord is connected - mine did not take until the power cord was connected. and make sure the installation CD is installed. If you have Vista, you may need to visit HP's website, even though the product said "works with Vista".
Posted on Jul 03, 2008
    Novelist:
    Champion:
  • 214 Answers
Do not edit the Registry - any mistake here will crash your computer and may require a reinstall of Windows and all other programs!
RIGHT Click My Computer - select Properties - select Device Manager - then RIGHT Click the DVD drive listing - select Update Driver (have your disk ready).
This should solve your problem.
Good luck.
Posted on Apr 25, 2008
Roxio Creator NXT Pro, doesn't recognise a DVD inserted to burn a DVD in Windows 8
Many people have a dvd player in their computer that burns cds but not dvds. Make sure it is a dvd burner as well. If not you'll have to purchase a dvd burner. If you want it to do more then purchase a blue ray burner or a dual layer dvd burner
Sep 13, 2013 | Corel Roxio Creator NXT - Complete Product...
I hooked up my GZ-HD3 camcorder to my CU-VD3U share station, copied all files to dvd-R and my dvd's will not play in ANY dvd player. How do I correct this?
It all depends on what file type your camcorder save video's in and what file types are compatible with your DVD player.
Many camcorders save files on a card as MPEG4, you have to check what yours does.
Its ok to write to a DVD but you have to make sure your DVD player can play MPEG4. If not then convert your files or save your files in a format your DVD player can recognise ie MPEG1 or AVI.
Finally, once you've copied videos in a format your dvd plays, make sure you "Finalize" the disk.
This means that you can't copy any more data, but it makes the disk readable on other players.
Feb 26, 2011 | JVC Everio Share Station DVD Burner Burner
My laptop says I don't have a DVD burner but I do. How can I reinstall it?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
Hi, my disk drive on my samsung r370 is making funny noises and is not recognising any disks?
or
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 16, 2010 | Samsung Computers & Internet
Recognised by windows as CD-RW but not as DVD-RW
Click Start
Click with the RIGHT mouse button on My Computer.
Click Properties.
Click Hardware.
Click Device Manager.
Click the '+' preceding 'DVD/CD-ROM' devices.
Double-click the CD/DVD device.
Click the Details tab.
The string displayed _should_ include 'DVD'.
Apr 05, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
Dvd not recognised
“To install, and Update Hardware, click to open “Computer” from the “Desktop”, check to see if there is a DVD-RW Drive (D :), for external different (E or F:).
I. Look in the “Device with Removable Storage area,” see if the device is present, if so? Do the following: to “setup” the ('player') for “Installation.”
II. Right click on (DVD) “Media Player” select (“Install”) follow all instructions thereafter.
III. If the area is (Blank?), “go to,” and 'click' on the "Start button" click all “Programs” scroll for a Media Disk Player”, open, and do the (“same as above”) for the installation. *Note: “Do the same for “Setup” (above) “Install.”
“Did this solution help? Helpful Ratings Feedback, appreciated, thanks paul7of9”
Feb 12, 2010 | Gateway Computers & Internet
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Problem wit my DVD writer
NO OS stated
NO PC stated.
NO job stated, just BURN something, vague.....
fail.
to burn a DVD takes skills
what is on said DVD, it can name 100 different vast things,
why not start with the missing story
what is it you wish to make? tell the helper what you are trying to do, a goal, like make my TV SOny DVD player play movies, using DVD movie format. (or bogus copies)
a real DVD movie.
a dvd with MP4 files. videos or 100 other types.
a dvd with data. (like docx files, xls, or ppt files? or?)
a dvd with songs, MP3 or 30 other types.
A dvd with software programs. like a copy of windows 7 install?
what?
Jun 11, 2017 | HP DVD 740VI 16X16 Dual Layer LightScribe...
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Dvd not working
do you have a dvd viewing program installed on the Computer.
Like Power DVD Or Nero.
Try installing one of these or a recent version of Windows media Player. I,d recommend Version 9-10 if your running XP.
mike @ Compurepair.
Feb 22, 2008 | ASUS DRW-1608P2S DVD RW Dual Layer Burner
HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner Logo
301 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
