Question about Husqvarna 165HP 42" Lawn Tractor
Bad valve i would like a service manual to rebuild the engine in a husqvarna riding mower
  • 760 Answers
Engine manuals are provided by the engine manufacturers. Find your engine brand and model number. If is a Briggs & Stratton for example, you can go to http://www.briggsandstratton.com/maint_repair/manual_and_more/index.aspx
and download a manual for your motor. The will not go into great details on rebuilding, but will list parts diagrams with part numbers.
Posted on Jul 23, 2010
In reference to Husqvarna riding lawn mower, what makes the engine surge
it could be several things. easy start would be to check fuel and air filters to make sure they are clean. if not then the carb may need to be cleaned or rebuild depending on how old the mower is.
Mar 21, 2015 | Husqvarna Garden
How could gas be entering the crankcase of my Husqvarna 48" riding lawn mower?
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing.
As the piston is continuously moving, the reverse happens giving oil at the intake or carb.
. Looks like a strip down, good inspection and rebuild of engine required .
Sep 20, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How can 10 HP briggs & stratton get fuel in the oil and what needs to be replaced?
The needle valve is not completely stopping fuel flow. The quick fix is to install a shutoff valve between tank and carbu
Aug 29, 2014 | Murray Garden
Lawn mower is smoking white
to much gas check to see if chock is off or replace bad fuel siliniod rebuild carberator
Aug 27, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
Here are a few tips to look at, I would first check your inline fuel filter to make sure its not clogged up. See Page 26 of the Manual for additional help.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
PROBLEM
Will not start
CAUSE CORRECTION
1. Out of fuel. 1. Fill fuel tank.
2. Engine not "CHOKED" properly. 2. See "TO START ENGINE" in Operation section.
3. Engine flooded. 3. Wait several minutes before attempting to start.
4. Bad spark plug. 4. Replace spark plug.
5. Dirty air filter. 5. Clean/replace air filter.
6. Dirty fuel filter. 6. Replace fuel filter.
7. Water in fuel. 7. Empty fuel tank and carburetor, refill tank with fresh gasoline and replace fuel filter.
8. Loose or damaged wiring. 8. Check all wiring.
9. Carburetor out of adjustment. 9. See "To Adjust Carburetor" in Service Adjustments
section.
10. Engine valves out of adjustment. 10. Contact an authorized service center/department.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need service manual for husqvarna zth6125kaa
Hi and welcome to FixYa, I am Kelly.
You can locate the service manual here for the mower chassis:
http://www.mymowerparts.com/pdf/Husqvarna_Service_Repair_Manuals/W0203003.pdf
For the engine manual I need your engine model number to pass you the repair manual for your Kawasaki or Kohler engine.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Not getting gas
the float is stuck closed clean the carb and that should take care of the problem. if not you will need a rebuild kit...good luck
Apr 05, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 165HP 42" Lawn Tractor Logo
164 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
