Question about Sport & Outdoor - Others
I have purchased three 750-watt power inverters in the last three weeks. They have all failed to work on the second or third use. The first two were the same brand. I replaced an old one that ran for several years. I am using it to run a 4.7 amp 120-volt vacuum cleaner motor that pumps up my air dock. I have it connected directly with marine cable to one of the boat batteries. The battery outputs about 12.8 volts DC. The fuses don?t blow, just No Output. I am using a three-wire 120-volt extension cord and am, wired neutral, hot and ground to the AC motor vial an on/off switch. The motor works fine when I run house power with an extension cord from the dock next to me. Could I be, just unlucky with new inverters and need to buy a forth one?
  • 1 more comment
  • hboyle362 Jul 22, 2010
    the first two inverters were 750 watts from O'Reilly auto parts
    Should I put a shut-off switch on the DC input?
  • hboyle362 Jul 23, 2010
    Yes this was helpfull.
    President:
  • 670 Answers
The problem may be that the inverter is undersized for the load. Is the 4.7 Amp rating the motor peak draw or the nominal one. What I mean is that it takes many times more power to start start the motor than when the motor is running. Typically it is 3 to 7 times more amps to start the motor than when it is running. It could be that starting the vacumm cleaner is stressing the inverter and it is causing it to fail prematurely. If you can find out the locked rotor current draw of the motor, the that would be the mininum size of the inverter.
Also, the type of inverter will make a difference on how the motor operates. A modified sine wave will make the motor run hotter than a pure sine wave inverter. Hope this helps.
Posted on Jul 22, 2010
  • 3 more comments
  • Stephen Lam Jul 22, 2010
    I don't think a switch on the input would do anything to keep the inverter from damage. I think the inverter that you are using are undersized and the startup current of the motors are causing them to fail. I would recommend that you get inverters with at least 4000 watt peak capacity if you want any kind of life from it. Hope this helps.
    Thanks, The manufacture of the Air Docks recommends a 750w Black & Decker. Do you think, as the motor ages it draws more current? Should an inverter fail because of an over load? I think I will try a 1000W
  • Stephen Lam Jul 23, 2010
    Somethings not making sense to me. You are saying that you are using a "4.7 amp 120-volt vacuum cleaner motor that pumps up my air dock" and the manufacturer is recomending a 750 watt inverter. If you multiply the current with the voltage you get watts. In this case it is 4.7 X 120 = 564 watts. However this is the running power, not the startup or surge power. For an AC motor, it can be anywhere from 3 to 7 times the running power. If we assume the worst case of 7, then the surge power is 3948 watts. I don't understand how the manufacturer could recommend a 750 watt invertor.
    Typically inverters have two ratings, a continuous and a surge power rating. Typically the surge power rating is twice the continous. Since you were using 750 watt (continuous power) inverters, even with the best case surge of 3 times the continuous power, 1692 watts, would be exceeding the surge power of the the inverter which would be 1500 watts.
    I tried to call Air Docks this morning, but only got a message. I would like to speak to someone there before giving you a recomendation on what should be the size of the inverter. Clearly it is not 750 watts, since 3 of them has failed you in a short period of time.
    Just to let you know, I do have a degree in electrical engineering and have knowledge with motor start up currents. I will try get a hold of the manufacturer to get back to you by this afternoon. In the meanwhile, if you need to get an inverter, for your air dock, I would recommend that you get at least one that has a surge capacity of 4000 watts to be on the safe side.
    Hi This is the motor that air dock uses
    http://www.blowermotorsplus.com/ProductD...
    I did have a used 700w inverter from Harbor Freight for years. Air Dock recommends an 800w from Block & Decker. Thanks
    Thanks for the info. I couldn't get the start current draw for this blower. However the web site show the max Amps as 5.7 so the continuous wattage is 684 watts. A 750 watt inverter is just marginally adequate to supply the continous power for the blower. As the bladders that you are trying to fill become full in order to lift your boat out of the water, that will increase the load to the motor, and thus overload your inverter, shortening out it life quickly.
    A larger inverter will give you more margin than a smaller one. Also a larger inverter will have better cooling capabitity as well. Typically an inverter are 90% efficient, so 10% of the power consumed by the inverter will be wasted as heat. So for a 700 watt load, will cause the inverter to generate 70 watts of heat. Your inverter is generating heat equivalent of a 75 watt incandescent light bulb when your blower is running.
    Plus a 2000 watt inverter is only twice as much as a 750watt inverter. Checking Amazon.com, a B&D 750 watt is $69, while a B&D 2000 watt is $139. You get nearly 3 times the power with at twice the price. You already spend that much on inverters. Get the larger inverter and spend more time on your boat instead of at the hardware store.
    President:
  • 1,099 Answers
All you need is to reduce the load that is placed on the inverter, if still decide to use the same numbers of load , you can go for the fourth inverter but of higher of higher wattage.
With this hope this will helpout......
  • Sanyade Akinwale
    Sanyade Akinwale Jul 22, 2010
    Just follow the solution provided initially.
    Good luck.....
    I had a 700 watt in the boat for years with the same blower motor. I may try a 1000 watt from Black & Decker. Thanks
    That the most recent one to fail. Thanks
Everbilt SUP54HD pump will it run on an inverter which is 500 watts cont. , 1000watt surge rated ?
you have to know the wattage of the pump motor to get that answer
if the wattage of the motor is 750 watts then --no-- as the continuous current draw is more than the 500 watt continuous allowed from the inverter
when an electric motor starts there is always a high current draw ( surge ) and that is why there is a surge rating for the inverter but that surge is for a second or less so the components of the inverter will handle it but they will over heat and fail if run for longer above the 500 watt rating
it best if the pump rating is around 85% of the inverter rating so if it is more , then get a bigger inverter
May 30, 2017 | Inverter Electronics - Others
I have a Cobra 1500W power inverter. The alarm is going off when the inverter is shut off. I drive a truck and have unplugged all appliances from the inverter and the alarm is still going off. What
I can only give some general thoughts on this, I have patched up a few inverters.
Their core parts rely on a component called capacitors these over time degrade with heat which reduces their manufactured value this will mean they fail to fully do their job. The usual result is not providing a smooth supply rail allowing voltage spikes which trip over and under voltage sensing firing off the alarm, more so when not loaded with appliances as spikes can become large.
Your appliances would be snubbing out these through their loading but this can be trouble because they are absorbing this extra energy which may damage them eventually.
This situation will possibly get worse with the inverter failing, it will need a service engineer to work on it or to purchase a new one if there is no local regional repair place.
Look up faulty capacitors in power supplies on the web for an insight.
Hope this helps........
Oct 23, 2017 | Watts Cobra Cpi1575 1500w 1500 Watt Power...
What's your problem?how many amps on a 1/2 horse sump pump
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Apr 28, 2012 | Black & Decker Husky 750w Power Inverter
I have a 750 watt Black and Decker inverter that will only start up when turned on but immediately goes to the caution light and does not charge anything. It worked for a short while, only a few minutes,...
or that your drawing too muc power, though 750W is a hefty supply. what are you plugging into it, is it grounded properly, do you have thick enought supply wires?
Jun 11, 2010 | Vector VEC043 750-Watt Power Supply
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Mar 03, 2009 | Inverter Vector 400-Watt Power
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Help in Houston
750 watts is low output for a side by side. 750 watts is not sufficient to provide starting power draw for the compressor start-up. The first three seconds or so require a surge of about five times that ratting.
Sep 12, 2008 | Kenmore 53642 / 53644 Side by Side...
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Sport & Outdoor - Others Logo
59 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
